Excessive first layer offset
jonnybergdahl
(@jonnybergdahl)
I ran the first layer calibration and ended up needing -1.85mm as offset. Isn't that a way too higher number?
How can I fix this?
Regards;
/jb
Veröffentlicht : 19/09/2020 2:59 pm
Oxygen
(@oxygen)
RE: Excessive first layer offset
depends on the height of the MINDA probe, if you find the numbers too high re-calibrate the MINDA sensor look here for some tips: https://help.prusa3d.com/en/guide/how-to-replace-a-m-i-n-d-a-sensor-mini_115145 (step 19 and on)
Stock MK4S with FW 6.2.6
Veröffentlicht : 19/09/2020 3:03 pm
jonnybergdahl
(@jonnybergdahl)
Thanks. Step 26 was what I was looking for!
/jb
Veröffentlicht : 19/09/2020 3:35 pm
ChillyPenguin
(@chillypenguin)
What is your new First Layer Z level?
I am at -1.475 on the textured sheet and -1.300 on the smooth. I may have to give this adjustment a try.
Veröffentlicht : 20/09/2020 10:33 am
osccresp
(@osccresp)
Good morning. I am totally new at 3D printers. I am facing dsimilar problem. I need to adjust the Live Z in the first layer calibration up to - 2 mm what is the maximum. Despite that, the nozzle is far away from the bed printing in the air. I followed step 26 to calibrate the MINDA sensor as well, and it is as it puts. After that, the distance is even more. I don't understand why, but no first layer can be printed because it is in the air. Any help?
Veröffentlicht : 25/09/2020 9:16 am
bobc
 bobc
(@bobc)
Posted by: @osccresp
If you find you need to adjust more than 2mm, and you followed the guide correctly, then your MINDA probe is probably faulty. Try contacting Prusa support.
Veröffentlicht : 25/09/2020 10:18 am
