ERR mintemp E1
I get this everytime i go to print or preheat... checked the thermistor and the heater in both extruder and bed and they are fine now what
Opublikowany : 30/12/2019 2:49 am
RE: ERR mintemp E1
Sorry to hear that. What's the ambient temperature in room with printer? It errors out if it is below 16 degrees Celsius, if you keep it in cold garage or so, that may be it. Bring it to warmer room or warm it up with haidryer before turning it on.
Other than that, could be bad thermistor, loose cable or broken wire. First check and reseat connectors on Buddy board, it could have been pulled out. Cut zipties on cables bundles and see if those had not pinched the cable and broke it. Contact customer support via chat on shop page if you need assistance with further diagnosis and replacement.
Opublikowany : 30/12/2019 4:00 am
