curling up
Michiel Bontenbal
(@michiel-bontenbal)
curling up
I've got a problem with flat designs (such as a case for my raspberry) is curling up at the edges.
What would you advise? Thanks in advance.
Posted : 12/03/2021 1:28 pm
Antonio
(@antonio)
Member Moderator
RE: curling up
can you post some picture of the issue? it can be easier to detect the issue 😉
I'm not an expert. Ma parlo anche italiano 😉
Posted : 12/03/2021 2:23 pm
Michiel Bontenbal
RE: curling up
Please find the link below.
You see on one side it's curling upward, while the other side is fine.
Grazie
link
Posted : 12/03/2021 3:21 pm
Antonio
(@antonio)
Member Moderator
RE: curling up
I see.
that's the material shrinking. What material are you using?
In any case you can try adding some 5mm brim, that will help.
Posted : 12/03/2021 3:26 pm
Michiel Bontenbal
RE: curling up
I use prusament PLA.
I tried a 5 mm brim, however the problem is still there.
The result is the same. Any other tips? Lowering heatbed temp? Slower first layer? Slower overall print speed?
What would you suggest?
Posted : 13/03/2021 9:43 am
Antonio
(@antonio)
Member Moderator
RE: curling up
Clean the bed and Live Z adjust
Try to lower the nozzle. PLA can't warp that way if the z height is right
Posted : 13/03/2021 9:47 am
Lize
 Lize
(@lize)
RE: curling up
As already suggested Live-Z is a likely candidate, on another post another member had an almost identical problem when it was too high.
Have a look at this post, printing a larger 0.2mm square makes it much easier to make adjustments than the built in process:
When I first got my printer I spent ages getting it right but am much better and quicker at it now should I need to for a different filament or get a new sheet, spending some time on the process is very worth while.
Posted : 13/03/2021 10:55 am
