Clicking from extruder and issue with print
FN_
 FN_
(@fn_)
Hello,
I am a fresh owner of Prusa Mini (not plus) 3D printer. It's a second hand from my friend who got an upgrade. The printer worked pretty fine in his house, but once I have tried to print anything, I got stuck. There are two main errors
  • printer stops printing after few seconds (can be seen on attached photos)
  • and than strange noise from extruter (can be heard on attached video)
I went through all steps in 3D printing handbook by Prusa and also many topics in this forum. I have also checked some troubleshooting videos and done my best debugging, but with no success.
Printer config
What I have tried so far
  • disassembled and cleaned extrured (see attached photos)
  • used a needle to cleanup the nozzle
  • used different filament - rPLA by EKOMB (same results)
  • used textured heatbead (just in case...)
  • adjusting the screw on extruder (tight / loose)
I have also created a shared album with photos and videos in full resolution, can be found on this link.
Clicking noise here
Here you can see when printer stopped printing
Does anyone know, what might be the issue here?
Best Answer by FN_:
After following steps in the article Squaring your MINI (especially the part Fine-tuning the XZ-axis) it seems the issue is solved.
This topic was modified 2 years temu 3 times by FN_
Opublikowany : 24/07/2024 9:34 am
FN_
 FN_
(@fn_)
It seems that the video is missing, I am sharing a link leading to video with the clicking noise
I have also
  • cleaned up the nozzle using cold pull
  • prepared the surface with dish soap and water
  • done first layer calibration
I think the issue is with the X axis. It seems like it's not parallel with the print surface.
This post was modified 2 years temu by FN_
Opublikowany : 24/07/2024 11:27 am
RE: Clicking from extruder and issue with print
Not a lot to go on but from that pic it looks like the bed is skewed now.  ie the filament on the left is not squished enough and on the right is far too squished, so much that the filament cant exit the nozzle.
You probably knocked the printer out of square when moving it.  It needs to be completely checked for square again and recalibrated.  There are various sources of info.  The manual would probably be a good place to start.  Google is your friend though, so something like https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/oh-no-were-skewed-prusa-mini-edition/ for example.
Opublikowany : 24/07/2024 12:00 pm
... another possibility is something on the back of the print sheet or stuck to the print bed causing one side to lift.  Plus, not the current problem - there are fingerprints on the print sheet which will cause other adhesion problems if not cleaned off.
Opublikowany : 24/07/2024 3:05 pm
FN_
 FN_
(@fn_)
Thank you guys. I have concluded the same - issue with X axis, even though the post is "Awaiting moderation" and thus not visible.
@diem: fingerprints were cleaned
I would expect to see the issue after first layer calibration, however it looks pretty OK (first few cm are before Z axis adjustment). :/
Opublikowany : 24/07/2024 5:30 pm
FN_
 FN_
(@fn_)
Ok, I am now convinced that the issue is caused by X not being parallel and thus Z is not 90° to base. See those two images below. This is wild, I think the height between heatbad and nozzle is > 1 mm.
Opublikowany : 24/07/2024 5:54 pm
FN_
 FN_
(@fn_)
Opublikowany : 24/07/2024 7:07 pm
2 ludzie polubili
Bargeau
(@bargeau)
The sensor of the first mini doesn't work correctly when the printer is cold.
Sometimes the nozzle touch the bed and the plastic can't go out. The extruder can't push the filament and this make a recognizable sound.
You have to preheat your printer for a couple of minutes
or check when you use it cold if the nozzle is in contact with the bed during the purge.
-> I ofen correct the Z offset when I use my mini.
They changed the sensor:  minda to the superpinda
Original Prusa MINI to MINI+ upgrade kit | Imprimantes 3D Original Prusa par Joseph Prusa directement (prusa3d.com)
Opublikowany : 30/08/2024 2:42 am
rikentor
(@rikentor)
You might want to try a different filament as well.
I had a very similar issue (extruder clicking, inconsistent extrusion), and in my case it turned out to be the filament. I was using Aurapol and it was causing clogs in the extruder.
Out of curiosity, I measured the filament with a digital caliper and in some places it reached up to 2.00 mm instead of 1.75 mm. I experienced this on multiple Aurapol spools.
Since switching to a different brand, I haven’t had this issue at all.
So it might not be your main problem, but it’s definitely worth ruling out.
Opublikowany : 19/02/2026 2:41 pm
