Can stringing be caused by tight bolts?
Jake
 Jake
(@jake-16)
I bought a printer second-hand recently and it printed fairly well for the first print (hardly any stringing) -
I then gave it a bit of a service by following a few YouTube tutorials which included cleaning out the fans, lubricating axis rods and tightening up the bolts. I didn't tighten them too much because I read here about tight bolts causing a lot of issues (e.g. problems with the extruder extruding filament etc.).
The printer seems to run very well now however I'm having a pretty persistent stringing issue now and I'm wondering if this can be caused by certain bolts being too tight?
The previous owner hardly used the Mini+, it had around 4 hours of print time so presumably it's not an issue with the nozzle - and I print at 215 for the first layer and 210 for the remaining layers.
Opublikowany : 02/08/2023 7:40 am
