can i use Spade to remove filament on prusa plate?
atomleef
(@atomleef)
I afraid of damage the coating.
Attachment removed
Publié : 12/03/2020 7:10 am
NibMaker
(@nibmaker)
RE: can i use Spade to remove filament on prusa plate?
You don't need to use a tool to remove prints from the Mini's flexible steel sheet.
If you're printing PLA or PETG, you can wait until the bed cools down a bit (40-45°C), remove the sheet, and flex the sheet a bit. The print should come off pretty easily.
Publié : 12/03/2020 7:30 am
1 personnes ont aimé
atomleef
(@atomleef)
thank you, then i will wait 🙂
i saw prusa himself do it in prusa mini 1st print tutorial
Publié : 12/03/2020 7:37 am
NibMaker
(@nibmaker)
When I'm impatient and don't want to touch the build surface, I use a beveled, smooth knife like this one: https://smile.amazon.com/gp/product/B075SLTY8B/
If you don't have a smooth knife/spade, as long as you don't jam the it into the build surface, it won't really be a problem.
Flexible steel sheets are awesome for tool-less print removal!
Publié : 12/03/2020 7:48 am
atomleef
(@atomleef)
@nibmaker
thank you
Publié : 12/03/2020 7:54 am
Chocki
(@chocki)
These work very well and you can replace the blade when it finally starts to get blunt, but I'm still on the same one after a year! 😀
https://www.amazon.co.uk/Plastic-Scraper-Sticker-Remover-Removing/dp/B07CZC21YF/ref=sr_1_6?keywords=plastic+razor&qid=1584004933&sr=8-6
Publié : 12/03/2020 9:23 am
Posted by: @chocki
Hate to admit it, but when I found a use for my blue plastic razor, I ordered an orange one for my Mk3! Works well and keeps parts from flying away as often compared to a more blunt scraper.
Publié : 12/03/2020 1:30 pm
Chocki
(@chocki)
Hmmm, maybe I do need to change my plastic blade, because when carrying out a linear advance calibration, the printed numbers fly off all over the place, when removing them. 😀
Publié : 12/03/2020 5:07 pm
