Calibration problem ?
fonbac@gmail.com
(@fonbacgmail-com)
The Z-offset setting does not proceed in positive values.
The actions I took in order are:
1. Assembling the printer.
2. Upgrade firmware from 4.0.2 to 4.0.4.
3. Calibrate the printer and set Z-offset to +0.400
4. New calibrate printer but select from 0.000 rather than +0.400.
5. After this setting Z-offset does not get positive values.
6. Restore factory settings but nothing again.
Is there anyone who has the same problem?
What can I do in this case?
Thanks.
Best Answer by atomleef:
is this a solution?
Questa discussione è stata modificata 5 years fa 2 tempo da fonbac@gmail.com
Postato : 07/03/2020 2:43 pm
RE: Calibration problem ?
Hi Xenophon.
why do you need Positive values...
Live Z is ALWAYS negative
the pinda probe should be set up with a Zip Tie, to result in the Nozzle being close to the build plate, but not touching the build plate, then you lower the Z height by adjusting the Live Z in a negative fashion, to bring the nozzle closer to the build plate until you get just enough 'squish' for a perfect layer.
I find the Prusa First layer calibration tool difficult to work with so I use
'Life Adjust Z My Way'
There is a Zip file at the bottom of the first post which contains sample files for use with a 0.4mm nozzle and either PLA, PETG or ABS
REgards  Joan
Postato : 07/03/2020 3:11 pm
1 persone hanno apprezzato
fonbac@gmail.com
(@fonbacgmail-com)
@joantabb
Hi Joan,
I tried both ways of calibrating ("Life Adjust Ζ My Way" - Mini included) and check Axis aligning also but cant print something !!!
The same settings but something is wrong.
Regards Xenophon
Questo post è stato modificato 5 years fa da fonbac@gmail.com
Postato : 08/03/2020 5:13 pm
xhillb61
(@xhillb61)
Looks like a clogged nozzle
Postato : 08/03/2020 6:18 pm
atomleef
(@atomleef)
is this a solution?
Postato : 10/03/2020 8:41 am
