calibrating first layer help
gald33
(@gald33)
Hi everyone, I ran calibration of first layer. The hotend touched and scratched by steel sheet all over, I tried moving it up by turning the handle but it only let me move it below 0 and not above 0, which is the initial and scratching height.
I thought the whole point of this calibration was to find the correct z value. Did I misunderstand something?
Veröffentlicht : 04/09/2021 7:02 pm
jcjames_13009
(@jcjames_13009)
PINDA height ?
Hi
Did you check PINDA sensor height ?
https://help.prusa3d.com/en/guide/7-preflight-check_204705
JC
Prusa MINI+ at home / Prusa MK3S+ in the Fab Lab / You can have a look at my designs here printables.com
Veröffentlicht : 04/09/2021 7:46 pm
gald33
(@gald33)
PINDA is higher
I did that but since the hotend touches the bed and the PINDA is spaced a ziptie thickness away from the bed, the PINDA is higher than the hotend. Isn't that the correct configuration?
Veröffentlicht : 05/09/2021 5:38 am
The Pinda should be a little higher than the nozzle. if the pinda is too high, the nozzle will scrape the build plate,
Veröffentlicht : 05/09/2021 8:48 am
gald33
(@gald33)
thanks
thanks, so I'll increase its height a little bit and try again
Veröffentlicht : 05/09/2021 8:53 am
BogdanH
(@bogdanh)
RE: calibrating first layer help
Posted by: @gald33
As you already scratched the print sheet, I think you should lower the PINDA.
[Mini+] [MK3S+BEAR]
Veröffentlicht : 05/09/2021 10:50 am
Mitglied
If you still need help, can you post a photo of your pinda and nozzle?  When you start calibrating, post an image of the little rectangle.
Veröffentlicht : 05/09/2021 11:01 am
gald33
(@gald33)
yes
Yes! it was a typo. I'll get the PINDA closer to the nozzle in terms of their height. Thanks.
Veröffentlicht : 05/09/2021 12:56 pm
JMH714
(@jmh714-2)
Wait... You got it fixed? I mean the filament went through now?
Veröffentlicht : 05/09/2021 1:02 pm
gald33
(@gald33)
RE: yes and no
Yes and no. I reassembled the extruder and got the filament through it, but it barely moves so I didn't get very far.
The reason I'm asking about the PINDA before fixing the extruder is that I thought that a print job like this first layer test would manage to get the filament all the way to the nozzle but that didn't happen, and in addition I scratched the steel sheet so I realized I have another problem.
Veröffentlicht : 05/09/2021 1:44 pm
JMH714
(@jmh714-2)
Ahh, gotcha!
The negative value is going lower while positive value going higher. The SuperPINDA should be about 1.5mm above nozzle. Or use the zip tie (1mm??) and put it under SuperPINDA while nozzle is touching steel sheet.
The 1.5mm is useful if you are using texture or powered coat sheet. Zip tie work well with steel sheet.
Veröffentlicht : 05/09/2021 5:31 pm
jcjames_13009
(@jcjames_13009)
Zip tie ok
Hi
On my side with zip tie it works for both steel and textured sheets
JC
Veröffentlicht : 05/09/2021 7:45 pm
JMH714
(@jmh714-2)
Posted by: @jcjames_13009
Hi
JC
Yes, you're correct. On my first Mini+, I used zip tie, but on my second Mini+ I used the printed out tool (1.5mm).
However, there are some people in here complained about unable to get calibrated correct because they reached -2.000 limit and still not proper calibrated. So, 1.5mm fixed the problem.
I compared my two Mini+ with zip tie and 1.5mm tool - Zip tie gave it approximately -1.650 while other Mini+ with 1.5mm adjusted at approximately -0.950.
Veröffentlicht : 05/09/2021 8:03 pm
