Brass fitting - correct direction ? (PTFE Fitting)
Hi; Trying to solve a jam problem, I removed the brass fitting to check for blockages, but didn't notice what direction it should go back in 🙂
The fitting has a perfectly FLAT side and on the opposite side a small CIRCULAR raised/edge.
Which side goes *into* the fitting hole? (I just don't want to take any chance of stripping the plastic threads).
Best Answer by Malcolm:
The side with the thicker threads goes into the plastic. The popped out side
Napsal : 03/08/2020 1:30 pm
RE: Brass fitting - correct direction ? (PTFE Fitting)
Napsal : 04/08/2020 12:39 am
Topic starter
answered:
@malcmcm
Thanks! Total newb question, but I had to be sure 🙂
Napsal : 04/08/2020 12:40 am
This is my first printer, I had to learn too and had the same question at the start.
Napsal : 04/08/2020 1:11 am
