Allen key broke off in screw from hotend 🙁
GaetanLE
(@gaetanle)
Hey guys,
I think I'm kinda cursed. I received my Mini some days ago, and after lots of bad prints I realized my heatbreak was clogged. So I ordered a new one from Prusa, so far so good.
Now I rebuild everything but my nozzle was a bit loose, so I wanted to try it again.
Now my allen key broke off in the screw (see picture), of course I can't remove it now....
I tried to drill in the screw with no success. What to do? Do I have to buy a new hotend?
( https://shop.prusa3d.com/en/mini/1017-assembled-hotend-mini.html)
Opublikowany : 02/08/2020 9:41 am
RE: Allen key broke off in screw from hotend 🙁
That's Unfortunate...
a desperate option may be to cut a slot across the screw  with a dremel and try a flat blade screwdriver
Opublikowany : 02/08/2020 2:24 pm
Henrik
(@henrik-3)
Hi, this happened to me as well during disassembly and troubleshooting. I managed to get all but one of the hex screws out (they were tightened insanely hard) and I had to resort to the highest quality tooling after the first allenkey broke, to get them out. It was the upper screw in my case that had the broken allenkey-piece.
I managed to pull the heatbreak out of the hotend regardless of the bolt still being there, and then drilled a hole in the heatsink from the opposite side drilling the stuck bolt away. I then as a backup could thread and insert a thicker bolt in that place, but it turns out the heatbreak seem to sit tight enough with the other two screws, so I haven't done that yet.
This post was modified 6 years temu by Henrik
Opublikowany : 03/08/2020 2:22 pm
GertL
(@gertl)
Hot glue a screwdriver or something to it ?
Gert
Opublikowany : 03/08/2020 2:25 pm
Henrik
(@henrik-3)
Posted by: @gert-l
In my case it was the unwise decision to use the ball-end of the allen key that ended up in the screw. It was then quite snuggly stuck by eating itself into the screw material. Tried various techniques to move the broken-off piece but drilling from the other side was the only solution I could find at the time. Maybe the OP could have better luck.
Opublikowany : 05/08/2020 1:26 pm
GaetanLE
(@gaetanle)
Well OP here, I tried Joan's way and it didn't went well... So I ordered a new hotend, it's due tomorrow 🙁
At least now I have some spare parts for the next accident...
This post was modified 6 years temu by GaetanLE
Opublikowany : 05/08/2020 1:52 pm
Are you goung to replace the grub screws with cap head screws to reduce the chances of a repeat occurance?
Opublikowany : 05/08/2020 2:22 pm
Posted by: @kormirluk
Hey guys,
And I would recommend this allen wrench set: Wera 3950 PKL/9 or this one 👍
Opublikowany : 05/08/2020 2:39 pm
GaetanLE
(@gaetanle)
That's funny @karl-herbert it is exactly what I did - new tools from Wera, the coloured one 🙂
@Joan: that's an amazing idea, exactly what I'm gonna do!
Thanks guys so far!
Opublikowany : 05/08/2020 3:35 pm
