[Solved] 2Pin power connector for hot end stuck in the PCB
zealousPrototype
(@zealousprototype)
I am replacing the hot end and the connector is stuck in the PCB, I am not really sure what the best way to get it out is. I have tried using needle nose pliers to hold connector and a hex key to push the snap fit in with no luck. I am paranoid if I use too much force I'll break it and have bigger problems. Has anyone encountered similar issues or have any suggestions?
Best Answer by zealousPrototype:
Solution was more force on the snap fit pin while supporting the back of the fixture with needle nose pliers. I did pick up some wire shrink wrap in case of a wire break to allow me to splice the wire together again. I also have access to solder.
Napsal : 30/10/2022 5:58 pm
zealousPrototype
(@zealousprototype)
RE: 2Pin power connector for hot end stuck in the PCB
Napsal : 01/11/2022 3:43 pm
