Poor man's automated chamber top vent
Now that firmware 6.3.3 no longer insists on waiting for the "Set the vent correctly!" prompt, but lets it time out after a minute, it finally makes sense to automate the vent switching. I opted for a cheap-and-cheerful solution: Attach little tabs to the inside of the vent slider and to the Nextruder, and let the Nextruder push the slider in the right direction via a bit of custom startup G-Code.
Here's my current setup: The slider part replaces the middle nut on the slider's mounting screw. The Nextruder part attaches via two of the lid screws -- you will need to replace the standard M3*25 screws with M3*30. Conveniently, my Core One kit came with two spares.
I had originally planned to move the tab on the slider further forward, such that it sits below the metal frame, well in the non-printable area. But that made it inconvenient to remove and replace the lid; hence the tab now sits just at the edge of the slider. The Nextruder part is designed to stay clear of the slider during normal printing. It will only start to brush against the slider tab when moved to Y=-5 mm, and fully engages at Y = -7 mm.
I'm attaching the STL files. I printed them in PETG, in the orientation shown below. The tab on the Nextruder provides enough flex to safe-guard against accidents, but more than enough force to move the slider.
The G-Code below goes into the Startup G-Code section in PrusaSlicer. I placed it just after the homing command (G28). If you decide to install this in your printer, please double-check the positions (by carefully moving the Nextruder manually via the front panel).
; Automatic vent control via Nextruder
; jm 9.6.25
G1 Y0 F6000 ; go to safe position
{if filament_type[initial_tool] =~ /.*(PLA|PETG).*/}
  ; Open vent
  G1 X85
  G1 Y-7
  G1 X100 F1000
  G1 X85 F6000
{else}
  ; Close vent
  G1 X115
  G1 Y-7
  G1 X100 F1000
  G1 X115 F6000
{endif}
G1 Y0 ; go to safe position
Napsal : 09/06/2025 7:33 pm
9 lidem se líbí
gb160
(@gb160)
RE: Poor man's automated chamber top vent
Now this... is cool 😎
Napsal : 09/06/2025 9:27 pm
gb160
(@gb160)
Show us a video of it working @jurgen-7 👍
Napsal : 09/06/2025 9:41 pm
1 lidem se líbí
Posted by: @gb160
I will try to capture the switching later today. But it's a quick move and rather unspectacular. 🙂
Napsal : 10/06/2025 5:01 am
1 lidem se líbí
gb160
(@gb160)
Posted by: @jurgen-7
Posted by: @gb160
You sound like my ex 😂
Napsal : 10/06/2025 5:24 am
4 lidem se líbí
Here's a quick video, showing just the short "open the vent" cycle. A bit harder to see than on yesterday's photo since I switched to black parts in the meantime, but I hope it helps to get an idea. It's quick and quiet compared to the XY homing which precedes it. 🙄
Edit: Darn -- is there any way to embed or attach videos on this forum? (Short of linking to Youtube or some other hosting platform, which I don't use.) Tried the Add Media function, both with an uploaded or a linked .mp4, and tried attaching the .mp4 -- neither shows up, let alone plays, for me. Maybe a plain old link will work?
https://www.e-basteln.de/file/Vent_movement.mp4
Napsal : 10/06/2025 8:17 am
5 lidem se líbí
gb160
(@gb160)
It's a great little mod mate. Sometimes the simplest ideas are the best ideas. 👍
Napsal : 10/06/2025 8:20 am
2 lidem se líbí
I have put this on Printables as well now for easier reference. (My first published model -- exciting!) Any improvement suggestions, of course please let me know.
https://www.printables.com/model/1323846-core-one-automatic-chamber-vent
Napsal : 10/06/2025 12:29 pm
7 lidem se líbí
Staldy
(@staldy)
Great mod 🙂
Napsal : 11/06/2025 4:35 am
Cédric
(@cedric)
Brilliant idea !
Napsal : 11/06/2025 3:02 pm
Yoyo
 Yoyo
(@yoyo-3)
Okay but can we use G-Code and the Nextruder to fill my taxes ?
Napsal : 11/06/2025 3:55 pm
1 lidem se líbí
Turns out that Prusa also likes the idea of letting the Nextruder move the chamber vent, and will implement it in the upcoming Core One L: https://blog.prusa3d.com/think-big-print-big-introducing-the-prusa-core-one-l_124294
They claim that this is not possible in the more compact regular Core One. I beg to differ! 😉
Napsal : 31/10/2025 3:20 pm
2 lidem se líbí
And there is another build on printables that uses a servo and the GPIO board: Core One - Servo Driven Automatic Chamber Vent
And @Jurgen, they should have given you credit for stealing your idea...
Napsal : 31/10/2025 7:25 pm
Gary AE1TG
(@gary-ae1tg)
Thank you for sharing.
My Core One hasn't arrived yet and this is on list of early mods.
Napsal : 01/11/2025 5:41 pm
1 lidem se líbí
Girak
(@girak)
Does a modification like this significantly affect the input shaping calibration?
I am worried about adding mass to the print head and altering the default input shaper calibration values. I'd rather not buy the accelerometer to recalibrate if I don't have to.
Napsal : 17/11/2025 12:32 am
Posted by: @girak
No, the effect will be negligible. I never weighed my Nextruder etc., but the total moving mass in the X direction (Nextruder with fans and electronics, mounting plate, X carriage) will be easily 400 g. The actuator lever that gets added to the Nextruder for the vent automation weighs 4 g including the weight of the slightly longer screws.
So it's a 1% change of the moving mass, which will not have a measurable effect on the acceleration profile and hence the input shaping. Rainer's remix with the actuator as an extension of the side cover might have even less added weight. So you can safely move ahead with the mod.
Napsal : 17/11/2025 6:57 am
1 lidem se líbí
