Poor man's automated chamber top vent
Now that firmware 6.3.3 no longer insists on waiting for the "Set the vent correctly!" prompt, but lets it time out after a minute, it finally makes sense to automate the vent switching. I opted for a cheap-and-cheerful solution: Attach little tabs to the inside of the vent slider and to the Nextruder, and let the Nextruder push the slider in the right direction via a bit of custom startup G-Code.
Here's my current setup: The slider part replaces the middle nut on the slider's mounting screw. The Nextruder part attaches via two of the lid screws -- you will need to replace the standard M3*25 screws with M3*30. Conveniently, my Core One kit came with two spares.
I had originally planned to move the tab on the slider further forward, such that it sits below the metal frame, well in the non-printable area. But that made it inconvenient to remove and replace the lid; hence the tab now sits just at the edge of the slider. The Nextruder part is designed to stay clear of the slider during normal printing. It will only start to brush against the slider tab when moved to Y=-5 mm, and fully engages at Y = -7 mm.
I'm attaching the STL files. I printed them in PETG, in the orientation shown below. The tab on the Nextruder provides enough flex to safe-guard against accidents, but more than enough force to move the slider.
The G-Code below goes into the Startup G-Code section in PrusaSlicer. I placed it just after the homing command (G28). If you decide to install this in your printer, please double-check the positions (by carefully moving the Nextruder manually via the front panel).
; Automatic vent control via Nextruder
; jm 9.6.25
G1 Y0 F6000 ; go to safe position
{if filament_type[initial_tool] =~ /.*(PLA|PETG).*/}
  ; Open vent
  G1 X85
  G1 Y-7
  G1 X100 F1000
  G1 X85 F6000
{else}
  ; Close vent
  G1 X115
  G1 Y-7
  G1 X100 F1000
  G1 X115 F6000
{endif}
G1 Y0 ; go to safe position
Opublikowany : 09/06/2025 7:33 pm
8 ludzie polubili
gb160
(@gb160)
RE: Poor man's automated chamber top vent
Now this... is cool 😎
Opublikowany : 09/06/2025 9:27 pm
gb160
(@gb160)
Show us a video of it working @jurgen-7 👍
Opublikowany : 09/06/2025 9:41 pm
1 ludzie polubili
Posted by: @gb160
I will try to capture the switching later today. But it's a quick move and rather unspectacular. 🙂
Opublikowany : 10/06/2025 5:01 am
1 ludzie polubili
gb160
(@gb160)
Posted by: @jurgen-7
Posted by: @gb160
You sound like my ex 😂
Opublikowany : 10/06/2025 5:24 am
4 ludzie polubili
Here's a quick video, showing just the short "open the vent" cycle. A bit harder to see than on yesterday's photo since I switched to black parts in the meantime, but I hope it helps to get an idea. It's quick and quiet compared to the XY homing which precedes it. 🙄
Edit: Darn -- is there any way to embed or attach videos on this forum? (Short of linking to Youtube or some other hosting platform, which I don't use.) Tried the Add Media function, both with an uploaded or a linked .mp4, and tried attaching the .mp4 -- neither shows up, let alone plays, for me. Maybe a plain old link will work?
https://www.e-basteln.de/file/Vent_movement.mp4
Opublikowany : 10/06/2025 8:17 am
5 ludzie polubili
gb160
(@gb160)
It's a great little mod mate. Sometimes the simplest ideas are the best ideas. 👍
Opublikowany : 10/06/2025 8:20 am
2 ludzie polubili
I have put this on Printables as well now for easier reference. (My first published model -- exciting!) Any improvement suggestions, of course please let me know.
https://www.printables.com/model/1323846-core-one-automatic-chamber-vent
Opublikowany : 10/06/2025 12:29 pm
7 ludzie polubili
Staldy
(@staldy)
Great mod 🙂
Opublikowany : 11/06/2025 4:35 am
Cédric
(@cedric)
Brilliant idea !
Opublikowany : 11/06/2025 3:02 pm
Yoyo
 Yoyo
(@yoyo-3)
Okay but can we use G-Code and the Nextruder to fill my taxes ?
Opublikowany : 11/06/2025 3:55 pm
1 ludzie polubili
Turns out that Prusa also likes the idea of letting the Nextruder move the chamber vent, and will implement it in the upcoming Core One L: https://blog.prusa3d.com/think-big-print-big-introducing-the-prusa-core-one-l_124294
They claim that this is not possible in the more compact regular Core One. I beg to differ! 😉
Opublikowany : 31/10/2025 3:20 pm
2 ludzie polubili
And there is another build on printables that uses a servo and the GPIO board: Core One - Servo Driven Automatic Chamber Vent
And @Jurgen, they should have given you credit for stealing your idea...
This post was modified 1 week temu by hyiger
"Some filaments feel the rain, others just get wet"
- Bob Marley
Opublikowany : 31/10/2025 7:25 pm
Gary AE1TG
(@gary-ae1tg)
Thank you for sharing.
My Core One hasn't arrived yet and this is on list of early mods.
Opublikowany : 01/11/2025 5:41 pm
1 ludzie polubili
