Nextruder Latch Screws/Springs
Conrad
(@conrad-2)
This may be too OCD, but as the latch moves slightly, the threads of the screws slide on plastic. This seems like it could change the force as things wear in. Would a smooth stud, with threads on each end, and tensioning nuts, be a better solution? There's probably nothing ready-made available, but a threading die and some 3 mm shaft would do the trick.
Napsal : 15/02/2026 4:17 pm
