My not-so-LITE MMU3 for COREONE
musokestrain
(@musokestrain)
I installed my MMU3 on the side as there was no room at the rear of the CoreONE due to the spools shelf. It required extending the MMU3 cable harness by about 300mm. A 600mm PTFE tube is passed through spherical bearing sandwiched by magnets between PETG fixtures in the acrylic top. The magnets allow a little lateral movement in addition to the bearing that swivels in response to movement of the gantry. I also had to increase the depth/size of the buffer. Seems to work OK.
This topic was modified před 10 months by musokestrain
Napsal : 29/08/2025 6:59 am
3 lidem se líbí
AstroStock
(@astrostock)
RE: My not-so-LITE MMU3 for COREONE
That looks interesting. I like the how simple the top ptfe penetration is! I have been looking for a passthrough that has some flex like this. Have you shared your mounting models, and links to parts, like the bearing?
Thanks for sharing
Napsal : 31/08/2025 11:26 am
