Customised Gcode header not executing
HainjeDAF
(@hainjedaf)
https://www.printables.com/model/1368525-core-one-nozzle-cleaner-arm
I have made the left side mounting version of this wiper arm.
Also I have added the accompanying Gcode to my gcode header in PrusaSlicer 2.9.4
But when printing, the CoreOne does not execute said code and wipe the nozzle...
What am I doing wrong?
Publié : 07/12/2025 2:12 pm
jan.d.slay
(@jan-d-slay)
RE: Customised Gcode header not executing
Can you please post your modified G-code online? Then we can check together to see if something might not be right.
Publié : 07/12/2025 2:24 pm
HainjeDAF
(@hainjedaf)
; ORIGINAL WIPER CODE commented out
;G29 P9 X208 Y-2.5 W32 H4
;NEW WIPER CODE
;Left Side gcode:
G0 X44 Y-15 Z1 F10000;
G0 X84 Y-15 Z1 F10000;
G0 X48 Y-12 Z0.5 F8000;
G0 X52 Y-15 Z0.5 F8000;
G0 X56 Y-12 Z0.5 F8000;
G0 X60 Y-15 Z0.5 F8000;
G0 X64 Y-12 Z0.5 F8000;
G0 X68 Y-15 Z0.5 F8000;
G0 X72 Y-12 Z0.5 F8000;
G0 X76 Y-15 Z0.5 F8000;
G0 X80 Y-12 Z0.5 F8000;
The G29 was original code. I commented out as said in description of wiper printable.
Ce message a été modifié il y a 5 months par HainjeDAF
Publié : 07/12/2025 3:01 pm
jan.d.slay
(@jan-d-slay)
Try this:
Publié : 07/12/2025 3:30 pm
1 personnes ont aimé
Posted by: @hainjedaf
You will need to move the print head manually using the UI controls to get the best set of coordinates. Also, if you are OCD you can add the following which will display "Wiping Nozzle" (or whatever you like) on the screen.
;NEW WIPER CODE
;Left Side gcode:
M117 Wiping Nozzle
Publié : 07/12/2025 4:53 pm
HainjeDAF
(@hainjedaf)
Well, when I export gcode, I can find the code in my file.
When exporting binary gcode (.bgcode) i can't check.
And indeed my OCD itches so I added m300 and M117 to signal wether the wipe is being done
I'll first have to wait my current prints before testing this with a prime cube
Publié : 07/12/2025 5:07 pm
jan.d.slay
(@jan-d-slay)
I would be interested to know whether it works.
Publié : 07/12/2025 6:05 pm
HainjeDAF
(@hainjedaf)
Prusa GCode viewer shows the wiper action if you select 'paths' to show non-printing moves.
I tried this with the same project saved both as ASCII gcode and binary gcode (BGcode).
As soon as the printer is finished (0:15 CET according to display), I can send it a PETG or PLA project and test what happens.
Publié : 07/12/2025 7:36 pm
HainjeDAF
(@hainjedaf)
Sorry for the late response but I had a job to run again without the changed code.
The changed code WORKS.
Removing the semicolons did the trick.
Also I added the messages with M117 and the beep with M300 to satisfy my OCD.
It all works.
Publié : 09/12/2025 12:04 pm
jan.d.slay
(@jan-d-slay)
I'm glad to hear that. I'll test it on my printer as well as soon as the wiping device is ready.
Publié : 09/12/2025 12:25 pm
It all works.
Interesting about the semicolons. They are just comments and will (should) be ignored by the parser.
Publié : 09/12/2025 3:19 pm
