Custom Filtration setup
Hylleus
(@hylleus)
Miembro
Hi there!
I recently designed a custom filtration solution which would allow the chamber fans to bypass the airfilter (due to the airflow restriction the filter introduces into the system) if filtration isn't needed. I am wondering a couple things now though:
  • I bought the Alveo3D fan that's used in the advanced filtration addon, will I need to set my firmware to DIY or Advanced Filtration?
  • Due to the aforementioned solution I designed, I'd like to know if having the filtration installed will completely disable the chamber fans, or will the chamber fans only be disabled when the filtration fan is running? Or is there a setting to choose what happens?
My final solution would be that, when filtration is NOT used for a print (PLA/PETG) the chamber fans can just run like usual with minimal airflow restriction due to the bypass, but when I'm running the filtration fan, the chambers fans would be disabled. Is this something feasible within the current firmware?
Thanks in advance!
Respondido : 08/09/2025 7:14 am
