Core One Cubed. Can I get some feedback?
Hello to everyone. I'm pretty new here having only had my Core One about 2 months, but it hasnt stopped printing since I finished putting the kit together. Before I had even completed it, having seen INDX and anxiously awaiting its release, I started to imagine a design for a way to manage filament and still match the look of the Core One. I went to the Core One's openly available files and using 1 top profile piece I designed the Core One Cubed. There are some other well designed options available on printables that were obviosly designed by engineers and look incredible, But, are pretty complex. My design consists of 2 files. The enclosure file and the bracket file. The entire cube consists of 8 enclosure pieces joined by 12 brackets. The novel and I think exciting part is that additional brackets can be printed and snapped anywhere into the frame to support filament rolls and route ptfe tubes etc. I am currently working on those accessory designs and the possibilities with these brackets is endless. I am hopeful that I can fit 8 rolls inside of the approximately 420mm cube. I am interested in hearing feedback from others on the design. I hope to list it on the printables store for a reasonable ammount but I have no experience listing designs. I was curious as to what others though a reasonable ammount might be. This is my first time asking for feedback so take it easy on me.
RE: Core One Cubed. Can I get some feedback?
I tried to add a poll asking whether you liked the design or not and whether you'd be willing to pay a reasonable amount to purchase it. Let me know what you think.
Sorry, I didn't realize the picture hadn't loaded.
The comparison with existing designs like the INBXX is not quite fair. Those are somewhat expensive, but they come with design files for all the bells and whistles -- handles, hinges, feet, spool holders...
I like your clean approach of keeping all profiles the same. But I am not sure whether the 42 cm height is going to work well for a spool storage box. It seems too crammed for two stacked rows of spools?
Maybe one row of spools in the upper part of the box, and room for the INDX PTFE tube arcs in the lower part? If this could replace the ugly "tank turret" hood Prusa provides with the MMU3 and apparently the INDX, that would be a benefit. But you would need to demonstrate that this works well, with easy access/handling when replacing a spool, and should provide designs for the required internal parts.
Personally I would probably be mildly annoyed by the fact that your frame's corners do not look the same as on the Core One, but that's just me and a certain level of OCD...
Thanks for your feedback! I tried to match the profile as closely as possible but this change was necessary to enable the inside to accommodate the snap brackets. I brought up the other solutions out there not as comparison but describing my reasoning for designing the Core One Cubed. Its a simple to print 2 files. One file, the bracket, is designed so that any end user can make changes to how they use it depending on what their needs are. I also designed it so only the bracket needs addition of heat inserts, magnets, etc. I pictured the individual whom this would appeal to doesnt want to print out 92 files to assemble their enclosure. I should have waited to mention all hopes for what I would like to be able to do with the design and let it stand for itself, as is.
I designed this to be a simple to produce and easy to modify design that even an individual with limited design experience (like me) could tackle the project without worry that it is too complicated for them to accomplish. I don't have a budget to make a website to showcase the design but I am confident that its simplicity and vast possibilities for modification will be appealing to some . So, if the individual is looking for a polished and engineered design and are not concerned about complexity, or the ability to make modifications to the design to fit their individual needs, they would be better served with the other options on printables. But, If the individual is interested in an affordably priced enclosure design that is easy to print themselves, and can be used in many different ways then this might be a good option. Thanks again for your feedback
I like the design, it looks great! Personally, I'm a strong proponent of open source, so if the design was released for free I'd be happy to donate to support it, but if it's strictly for purchase, I most likely wouldn't buy it.
Love the design.
The corner design doesn’t mirror the CoreOne but I don’t think that it needs to. It compliments it just fine.
I’m just not getting the big picture in my mind on how it’s used in practice so can’t say if I would be interested. Perhaps some pictures in use would help.
I too am more likely to make a donation for something I find useful than to purchase it up front though I suspect that I’m in the minority.
Please continue to show updates.
@printscharming has not logged in since March 27th. Hope he will stop by again soon!
Ditto. I am hoping to see his progress.
Thanks for the feedback. Chuck, I plan on releasing the files in the near future. I bought My core one excited about the INDX and really stretched my budget to get it. At the time, They anticipated $499 for 4 heads and $699 for 8. I thought it would be worthit to save and at least be able to get. the 4 head when it comes out. After seeing the "new" pricing i have become a bit disheartened and even second guessing my purchase of the Prusa. If I had originally know that the INDX was going to be offered at the price it is now I would have known upfront it was around a $2000 price tag for the core one with 8 heads I may have chosen different hardware. Don't get me wrong, I think the Core one is an incredible printer, but if I had intended to stay with 1 color printing, I could have chosen much less expensive options, and if I knew the end cost, of 8 toolheads I could have weighed my options there too. I can blame nobody but myself for purchasing a brand based on a technology they were "almost ready" to release at a reasonable price before I see the actual price in writing. My $40 voucher seems to carry much less weight against a $999 INDX. Sorry for the long rant, but that is my explanation for why ive just let the project stagnate since seeing the "updated" price. I will release it soon, I just invested so much time in making the design it took a lot of the windout of my sails when I have come to the conclusion that the INDX is going to be out of my budget. It is a great design, and I'm sure will be capable of amazing things, but if its not in the budget its not in the budget. Thanks again for the input.
Yes, that was one heck of a price increase and for those of us in the USA the shipping (with tariffs) adds to the insult.
Chose Prusa for my first printer (a MK-3), fought the MMU-2, good success with the MMU-3, finally the MK-4 with another MMU-3.
Then when they opened the INDX for the first round I Ordered it with a CoreOne+.
Will see how this goes. But my unquestioned loyalty to the Cult of Prusa will end if they don’t come through in a big way. They will no longer be able to retain my business coming up a day late and a dollar short.
The Core one is an awesome printer and I'm sure the INDX will take it to another level. I definitely don't want to sound like sour grapes because I can't afford the INDX. I just wish I had known the actual final cost before I spent so much time designing an enclosure I won't be using. Regardless, I plan on releasing the design as soon as I find time to create the page with instructions etc. and hope that some people will be able to use it.
Cheers!
