Zorbido Extruder - Rigid mount, better retraction, easier assembly, faster heating and more!
Condorman
(@condorman)
I preordered and received the Rapido hotend from Fabreeko.com and designed a Prusa MK3s+ x-end adapter for it. It uses an Orbiter 1.5 extruder. I call it the Zorbido because I built mine off the Zaribo Orbiter adapter. Zaribo + Orbiter + Rapido = Zorbido.
Initial tests have been unbelievable.
I normally run anywhere from .8mm to 1.6mm of retraction on my dozen stock Prusas. With the Rapido using a .4mm nozzle, I have been able to drop my retraction down to .2mm! And this is with PETG! I've never been happier with a hotend.
Pros:
  • Rigid mount for 1-handed nozzle changes.
  • Heatbreak reinforced by screws.
  • Heatblock doesn't obstruct nozzle.
  • Thermistor and heater wires are far away from the nozzle so no more dirty or frayed wires. They are also reinforced with a metal spring so they can't be bent easily at the connection.
  • Comes with connectors for both wires
  • Comes with 2 .4mm nozzles, 1 reinforced.
  • Heats up insanely fast.
  • Silicone sock covers a huge surface area and won't easily come off or be destroyed.
  • Without the groove-mount adapter, it's actually 10mm+ shorter than an E3D v6. I actually had to increase the distance between it and my extruder to not need to change too much geometry.
  • Dropped my retraction my a TON.
  • It's blue or black.
Cons:
  • Price? It's like, 50% more expensive than a v6, but since it comes with a thermistor and heater, it's not more expensive than a Dragon.
  • Wires being higher up means it won't fit perfectly on some mounts designed for the v6. Currently my mount needs more optimized wire management.
Note: the retraction test in the photo shows retractions increasing by .1mm at each ridge. Starting at 0mm retraction. Notice anything? There's no stringing regardless of retraction settings! Insane!
Note2: I also got rid of most of the embedded nuts in favor of heat-set inserts for easier printing and assembly.
Veröffentlicht : 26/12/2021 8:19 pm
Condorman
(@condorman)
RE: Zorbido Extruder - Rigid mount, better retraction, easier assembly, faster heating and more!
https://www.prusaprinters.org/prints/106210-zorbido-hotend-adapter
Veröffentlicht : 26/12/2021 8:43 pm
