Y axis inprovements collecting thread
pingu
(@pingu)
The parts from thingiverse for mk3 are working. No more shitty u bolts!
Opublikowany : 18/12/2019 10:26 am
padigree
(@padigree)
RE: Y axis inprovements collecting thread
Thank you for the picture.
 Arethese the normal 8mm LM8UU bearings? (X&Z are 10mm?)  Thought about replacing them with Misumi LMU8 and the X&Z with Misumi LMU10W. Nice experiences with Igus bushings, but had to replace them after ~1,5 years due too high tolerances -so I decided to use more Misumis (Quite well after a couple of years if you lubricate and service them correctly. Also the rods are nearly as at the beginning)
Have you any plans of changing the bearings?
This post was modified 6 years temu by padigree
It’s better to give than to receive. Especially advice.
Opublikowany : 18/12/2019 10:59 am
pingu
(@pingu)
https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/worlds-first-teardown-bom-bill-of-materials-closest-look-for-prusa-mini/#post-179792
There i have done a teardown, rest of the printer is following tomorrow. Its back together again and peints, but have no time today to post the missing things.
Actually i dont plan to replace the bearings, but i greased all of them on all axis.
Opublikowany : 18/12/2019 11:11 am
padigree
(@padigree)
Thanks again, Haven't seen you've updated it yet. Great work and I think useful for many people waiting for their printers 😀
Opublikowany : 18/12/2019 11:56 am
weak
 weak
(@weak)
Posted by: @pingu
So the bearings are not properly greased, just like on the MK3?
Posted by: @pingu
Could you elaborate what the advantage of these u-bolts is?
Thanks!
Opublikowany : 18/12/2019 12:18 pm
Ubolts can hold the bearings tighter than cable ties which was the original solution.
but, if over tightened the ubolts can damage the bearings and cause damage to the smooth rods...
Opublikowany : 18/12/2019 5:27 pm
1 ludzie polubili
ekkilein
(@ekkilein)
@pingu
Which ones (thingi number) are you using?
Opublikowany : 31/12/2019 1:09 pm
JSR
 JSR
(@jsr-2)
Posted by: @pingu
Can you share the Thingyverse link please?
Opublikowany : 01/03/2020 8:10 am
Benji
(@benji)
I printed and replaced my u-bolts with this model: https://www.thingiverse.com/thing:3068363
However, the single right mount will not fit because of the x-z assembly mounting bracket. I had to modify that bearing mount a little bit on one side.
Prusa Mini Silicone Bed Leveling Mod: https://bbbenji.github.io/PMSBLM/
Opublikowany : 01/03/2020 7:46 pm
Oliver Thomsen
(@oliver-thomsen)
I used two of  these for the left side https://www.prusaprinters.org/prints/10429 and made my own remix for the right side https://www.prusaprinters.org/prints/29435-prusa-mini-y-axis-bearing-strap-right-side
Opublikowany : 13/04/2020 4:16 pm
