WS7040 7040 Blower Fan On mini
KAD370
(@kad370)
Hi all!
I’m playing with idea of using brushless turbo fan for cooling prints. I found this fan. I had that idea few years ago on my diy build, but didn’t go with it, since I was not sure how to connect it to printer board.
€ 59,02 20% Off | Mellow 24V Brushless Centrifugal Air Blower DC WS7040 7040 Blower Fan 6.5kpa For VzBoT HevORT 3D Printer https://a.aliexpress.com/_m05ao4Q
Description:
When you want to use the potentiometer knob to control the fan speed, you only need to connect the driver board directly to the 24V DC power supply.
When you need to use the motherboard or Raspberry Pi to control, just take out the potentiometer, connect the signal pin of the driver board to the 5V or 3.3V pin of the motherboard, and connect it to GND.
Marlin:
enable "FAN SOFT PWM" and set "
SOFT PWM SCALE"to 5
Duetboard:
https://duet3d.dozuki.com/Wiki/ Connecting_and_configuring_fans
Klipper
[fan]
pin: host:gpio26
Klipper
[fan]
pin: host:gpio26
hardware_pwm: False
cycle_time: 0.005
will this work with buddy board?
As I understand it, I have to connect power to main power supply ( thinking to use meanwell 24V 350W power supply. And disconnect potentiometer and connect signal wire to 5V pin and ground wire of potentiometer to negative wire of fan output?
Postato : 24/01/2023 8:45 am
