Wrong color loaded on manual color change
Rob
 Rob
(@rob-8)
I've just started experimenting with changing colors and so far, all have worked out ok except for when I mistakenly loaded the wrong color filament. I realised almost immediately and paused the print but could not think of how to change to the correct color without wrecking the print.
In this instance I kept with the wrong color and used it as a learning experience.
Question: If such a mistake as this happens, is there some way of changing to the correct color filament without losing the print?
Postato : 22/11/2022 12:44 pm
RE: Wrong color loaded on manual color change
Don't know about the mini specifically but on a mk3 you would just use the lcd based menu and select change filament, not pause print.  Then load in the filament you want.  Does the mini not have that option ?
Postato : 22/11/2022 12:48 pm
René
(@rene-3)
Yes the mini has that option too.
While printing, select the TUNE option and then CHANGE FILAMENT.
Postato : 22/11/2022 1:24 pm
Rob
 Rob
(@rob-8)
Thanks to both Neophyl and René for giving me the answer so quickly.  I'll try it before my next brain fade. 😊
Postato : 22/11/2022 8:56 pm
