When will we have Octoprint support?
Page 2 / 4
joo
 joo
(@joo)
RE: When will we have Octoprint support?
@crawlerin
We got our Prusa Mini working with Repetier Server tonight, so OctoPrint should also work
thingiverse.com/joo
Publié : 19/12/2019 6:44 pm
2 personnes ont aimé
towlerg
(@towlerg)
@joo
Was that by using the mini USB on the motherboard?
Publié : 19/12/2019 7:54 pm
joo
 joo
(@joo)
@towlerg
yupp, Micro USB on Prusa to USB-A on the Rapsberry; Basic Settings:
Marlin
/dev/serial/by-id/usb-STMicroelectronics_STM32_Virtual_ComPort
115200 Baud
thingiverse.com/joo
Publié : 19/12/2019 8:17 pm
MVasilakis
(@mvasilakis)
I can confirm that Octoprint works just fine with the PrusaMini and via the mini usb port. I haven't been able to do extensive testing yet but PrusaSlicer sends a file just like on the MK3s and initiates the print just fine.
Photo: ?dl=0
Publié : 20/12/2019 7:20 pm
1 personnes ont aimé
Posted by: @manousos-v
Great news! I am really depending on Octoprint these days, and was wondering if it would be a problem with the Mini. Thanks!
Publié : 20/12/2019 9:28 pm
BunchaHooey
(@bunchahooey)
@manousos-v
Thank you so much for testing this out!  That clears up some massive confusion, and  I am massively relieved 🙂
Publié : 20/12/2019 9:45 pm
Crawlerin
(@crawlerin)
Thanks a lot for testing this 🙂
Publié : 20/12/2019 11:52 pm
MVasilakis
(@mvasilakis)
@crawlerin
No problem. First octoprint print is still going strong.
Publié : 21/12/2019 1:59 am
Sal
 Sal
(@sal)
@manousos-v
So you are still using PrusaSlicer to prepare your models right? I was hesitant on Octoprint cuz I thought you would have to use their slicer if you want to print remotely
Ce message a été modifié il y a 6 years par Sal
Publié : 21/12/2019 11:58 pm
MVasilakis
(@mvasilakis)
Posted by: @sal
@manousos-v
Still using Prusa Slicer. Nothing has changed. We've sliced multiple prints now (still firmware 4.0.0) in PrusaSlicer and sent to Octoprint without issue.
Publié : 22/12/2019 2:01 am
Craig Trader
(@craig-trader-2)
Posted by: @sal
With OctoPrint, by default, it expects you to upload pre-sliced Gcode files. As an option, you can install and configure a slicing plugin so that when you upload an STL file, it will get sliced and then printed, but it isn't mandatory.
I solve problems, usually with computers ...
Publié : 22/12/2019 5:10 pm
Posted by: @wcraigtrader
I haven't tried it, but I believe that's based on a very old Cura version and it'll be slow. It does work, but PrusaSlicer is well integrated with Octoprint and lets you send generated gcode directly for printing. The two are a very powerful and flexible combination.
Publié : 22/12/2019 6:29 pm
CG-3D
(@cg-3d)
I can confirm that you can use octoprint to an extent, however I have noticed that the run-out routine does not work. At least not for me. The printer would pause and unload, but not allow you to reload and octoprint would not either. I could not reload nor resume a print.
Publié : 28/12/2019 4:57 pm
Sal
 Sal
(@sal)
@lcgulotta
Rather interesting observation
Publié : 28/12/2019 4:59 pm
Posted by: @towlerg
Personally the principle reason for running something like Octoprint is that it is independent of the processor running the printer.
This is a point that I think is often missed: It's nice to have on-board monitoring features, but for reliable monitoring of any process, you want "out of band" monitoring. I want my Octoprint install 100% independent of the printers it's monitoring, including power and any other dependencies. Otherwise there's no knowing whether the monitoring is simply offline or the printer is in distress.
I can understand why Prusa wants to add popular features, but allowing easy integration with Octoprint is essentially a gimme that costs Prusa nothing and provides very powerful capabilities that work across a mix of printers. I hope Prusa has or is considering sponsoring Octoprint development as it's doing a lot to make the hobbyist/home printing environment safer and more reliable.
Publié : 28/12/2019 5:09 pm
Sal
 Sal
(@sal)
@bobstro
I have no doubt that Prusa will get it right from a systematic point of view if they are looking into remote solutions with prusa connect etc.. If I were Jo I would consider acquiring octoprint same way IBM acquired Redhat. Just my 2sense
Publié : 28/12/2019 11:16 pm
fns720
(@fns720)
@manousos-v
How did you configure your Octoprint's serial settings for Prusa MINI?
Publié : 30/01/2020 10:27 am
finariel
(@finariel)
Unfortunately its not working for me =/ Octorpint says that it has no more Baudrates to try ^^
What am I doing wrong? Prusa Mini is connected to a Raspberry Pi 3B+ via Micro USB Cable
Publié : 05/02/2020 10:18 pm
MVasilakis
(@mvasilakis)
@fns720
Ce message a été modifié il y a 6 years 2 fois par MVasilakis
Publié : 05/02/2020 10:41 pm
finariel
(@finariel)
@manousos-v
Have you installed Octoprint from their page or the Prusa editor? Could you share your Mini-Profile / Settings with us?
Publié : 05/02/2020 10:45 pm
Page 2 / 4
