Vertical movement Is loud
When my printer moves across the vertical rods it makes a loud rubbing noise. It is only noticeable when moving quickly, like moving fully up or down with a single command. Is this a problem with lubrication or parts?
RE: Vertical movement Is loud
What printer you put it in user mode section also lube rods
Prusa mini. Any suggestion on what kind of lubrication to use on the rods
Prusa recommend White Lithium grease.
Other people recommend other greases.
I have used LM2 yellow lithium grease, TF2 White Lithium Grease, Slugslime Precision oil and PrusaLube white lithium grease
on different Prusa Printers with no noticeable difference.
the prusa printer is a low load application, so it is likely that any lube will be beter than no lube...
However the subject of Lube, is a can of worms...
Do not Lube the lead screws. the POM nuts ate supposed to be Lube free...
