Show your enclosures
Stránka 1 / 8
SS220
(@ss220)
Anyone care to share their enclosures for their Mini? Working on a lack table enclosure now and will post pics when it is finished.
Napsal : 09/02/2020 6:16 am
2 lidem se líbí
SS220
(@ss220)
RE: Show your enclosures
Work in progress. Happy with the progress so far.
Edit: Can anyone tell me how to keep the pics from looking squashed?
Attachment removed
Napsal : 10/02/2020 6:39 am
5 lidem se líbí
Oxygen
(@oxygen)
I have read the forum only supports photos in portrait mode
The enclosure look very pritty -- I will build the same enclosure when my printer arrives
did you use PLA or PETG for the orange parts?
how did you get the front of the printer in multi color?
Stock MK4S with FW 6.2.6
Napsal : 10/02/2020 7:23 am
SS220
(@ss220)
@oxygen
I used PLA for the enclosure parts. For the front plate, I used the model of prusaprinters.org
https://www.prusaprinters.org/prints/15346
Printed in multicolor using my Palette 2 pro.
Napsal : 10/02/2020 12:24 pm
1 lidem se líbí
bradmcgonigle
(@bradmcgonigle)
I got my Mini at the end of December and after a month and I finally put it in a Lack enclosure.  The enclosure is mostly for aesthetics, organization and keeping things out of reach of my 18 month old.
All the parts were printed with white Overture PETG.
Current addictions (beyond Lack hardware):
Future planned additions:
  • Basic air filtration (still trying to find something that uses a cheap HEPA filter I can find on Amazon US)
  • Drawers (going to have to scale them in order to print them on the mini)
  • Power brick mounts
  • Mount the Raspberry Pi
  • Cable management
Napsal : 13/02/2020 1:41 am
bradmcgonigle
(@bradmcgonigle)
Not sure why the image gallery didn't work. Here are the photos https://imgur.com/a/lDUO31B
Napsal : 13/02/2020 1:38 pm
3 lidem se líbí
Bill Plein
(@bill-plein)
@bradmcgonigle , @stevensmith
Nicely done!
Austin, Texas, USA
Napsal : 13/02/2020 6:25 pm
1 lidem se líbí
JBinFL
(@jbinfl)
Not gonna lie, that white looks good.  nice job.
Strange women, laying in ponds, distributing swords, is hardly a basis for a system of governance!
Napsal : 14/02/2020 12:30 am
1 lidem se líbí
3Dprintedgr
(@3dprintedgr)
@bradmcgonigle
Really nice setup!
Did you make that concrete base? Or is it from a store?
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Napsal : 15/02/2020 12:40 pm
bradmcgonigle
(@bradmcgonigle)
Posted by: @geoper2
@bradmcgonigle
Really nice setup!
It’s a store bought 16” x 16” concrete paver. Costs around $3 at my local Lowe’s hardware store.
I got it mainly to help with the sound reverberating through the Lack table and it’s made a huge difference.
Napsal : 15/02/2020 1:36 pm
1 lidem se líbí
Syd
 Syd
(@syd)
Got mine in December, and have been gradually adding to the enclosure and build.
I started with a LACK "coffee" table that I already had as a base which allows for more tool and filament storage.  Then I added two normal LACK tables on top.  The middle one is attached top and bottom with some LACK brackets I found on thingiverse.  The enclosure is the Original MK3 LACK enclosure ( https://www.thingiverse.com/thing:2864118) with acrylic panels from printedsolid.com.
I've added more small improvements than I can  list.  Among them:
  • Octoprint with a Logitech C270 camera.
  • Temperature controller with 2x 80mm and 1x 120mm fans
  • 2x AFO fire balls
  • POE HD security camera for an overhead print view that's not dependent on the Octoprint running.
  • IKEA Lerberg DVD rack on its side as a filament rack
  • Drawers ( https://www.prusaprinters.org/prints/17762-lack-enclosure-drawers/files) that I slightly shrunk down to fit on the Mini bed.
  • A themometer/hygrometer system that I can see from my camera
  • Grommets through the bottom because the Original enclosure leg pass-thrus are way too small
  • USB LED lights that I had lying around. From the pics I need to secure them better 🙂
Debating different ways to exteriorize the filament like @stevensmith above, but I haven't found any that I 100% like.  I like that inside it's sheltered from dust.  But outside would look tidier.
Napsal : 19/02/2020 7:33 pm
1 lidem se líbí
Syd
 Syd
(@syd)
Posted by: @bradmcgonigle
  • LED lighting (I should have paid attention to the color temperature because the “white” is very cool/blue)
I like the blue!
Napsal : 19/02/2020 7:40 pm
1 lidem se líbí
bradmcgonigle
(@bradmcgonigle)
I have one of these drawers printed so far and plan to print two more.
Are your fans only for cooling? I’m looking to add a filtration system based on https://www.thingiverse.com/thing:2678578  but I need to modify it to fit filters I can easily find locally or on Amazon US.
I like the blue!
The blue has grown on me for sure. I was originally looking for more natural lighting.
Napsal : 20/02/2020 2:46 am
Syd
 Syd
(@syd)
I used that exact thing for my 120mm! There is definitely space for a filter, but I haven't looked for one since it would slow down the fan cooling effect. I have a window next to the printer so my plan is to run a vent hose (maybe with a mag connect so I can take it on and off) if I print anything smelly. I have a HEPA filter running in the room and it takes care of most of the smell from PLA.
Napsal : 20/02/2020 1:45 pm
digbat
(@digbat)
Sized to give room for the petulent MMU2S and regular in-stock DIY board sizes - roughly 600mm x 1200 mm so one cut and build an almost square box. Uprights are on sale at the time 1200 mm long small studwork.
I some printed joins to reinforce the joints and screwed through the boards into the uprights - modular based on cutting the studwork into 4 equal lengths. Nothing painted, primed, etc - I await the patina of time and use. Has wheels,  the back can pull off for access.
Mad scientist MMU2S buffer experiments - because I have human fingers and patience - the prusa buffer is too irritating to use (and no, the ski-jump did not work.
Cheers
digbat
This post was modified před 6 years by digbat
TANSTAAFL
Napsal : 21/02/2020 7:45 am
Scott Frazer
(@scott-frazer)
A Lack v2 enclosure. You can't print the files as given on the Mini. A bunch of them are just a bit too long. So I cut them up in Microsoft's 3D Builder and added some pins/holes so I could super-glue the pieces together.
The v2's U-shaped frame at the top turns out to be excellent for mounting an LED string. I went with the Sylvania kit and got the extender/flex connector kit as well. That lets me have the lights inside and another strip underneath the table.
I also ran a USB extension under the table and glued it in front. Super helpful.
I think I need to get a paver to help with vibration.
Link to Imgur gallery: https://imgur.com/gallery/JJ6OCUd
This post was modified před 6 years 2 times by Scott Frazer
Napsal : 22/02/2020 4:56 am
2 lidem se líbí
bradmcgonigle
(@bradmcgonigle)
@sfrazer Looks great!  Any chance you’d be willing to share the v2 files split to allow them to be printed in the mini?
Napsal : 23/02/2020 3:45 am
SS220
(@ss220)
@sfrazer
Nice looking setup!
Napsal : 23/02/2020 5:19 am
Scott Frazer
(@scott-frazer)
@bradmcgonigle
Sure! I've uploaded them here: https://www.prusaprinters.org/prints/23923-lack-enclosure-v2-modified-to-print-on-the-mini/
Napsal : 23/02/2020 5:26 am
Matteo Cristini
(@matteo-cristini)
@neil-t
Hi, thanks for posting, but this is the Mini thread! Cool enclosure tho
Napsal : 23/02/2020 5:40 pm
Stránka 1 / 8
