Prusa Mini in a Festool Systainer
Konstantin
(@konstantin)
I'm looking to make a portable setup with Prusa Mini and was looking at Festool Systainers to move the machine. Prusa states that machine's outer dimensions are 320x330x380, while the closest systainer I found has 389x275x39m internal dimensions (275 is standard depth across the whole range).
I was wondering whether there is a reasonably straightforward way to partially disassemble the machine for transport to fit in the systainer? Or whether there are other suggestions for transport solutions?
Thank you!
Publié : 13/05/2021 9:36 am
Membre
RE: Prusa Mini in a Festool Systainer
No.  Disassembly will require you to make too many adjustments and recalibration.  I would find a bigger box.
Publié : 13/05/2021 10:39 am
Konstantin
(@konstantin)
Thank you, Chuck. It's quite a struggle to find a ready-made transportable case like this, but i guess I'll just have to look harder.
Publié : 13/05/2021 11:41 am
adesir
(@adesir)
Stanley FatMax case? The 50L (STST1-80150) should be OK.
Mes modeles publics
Publié : 13/05/2021 1:08 pm
Konstantin
(@konstantin)
@adesir thank you for the suggestion. the thing is though that they only give external dimensions, which are 66,5 x 40,4 x 34,4, and considering Mini's 320 x 330 x 380 this may be a very tight fit.
Publié : 13/05/2021 1:59 pm
Membre
@adesir
From my iPhone, it think you are right but I do not have my reading glasses.
Publié : 13/05/2021 2:19 pm
3dpr
 3dpr
(@3dpr-2)
I would check out ZARGES aluminum boxes for this purpose: https://www.zarges.com/en/products/packaging-transportation/boxes
3dpr
Publié : 15/05/2021 4:45 am
