Prusa mini Fysetc clone - log of a journey
Stránka 6 / 9
Review
I am finishing my review on theBIQU BX and an update FYSTEC clone
Napsal : 23/09/2021 3:45 pm
Gepstra
(@gepstra)
Heatbreak
Welp my clone arrived today, started to unpack and checked the heatbreak and unfortunately it's the loosey goosey one where the PTFE goes all the way down.
This post was modified před 4 years by Gepstra
Napsal : 28/09/2021 5:25 pm
BogdanH
(@bogdanh)
Posted by: @gepstra
...it's the loosey goosey one where the PTFE goes all the way down.
- you know what to do, right? 😊
[Mini+] [MK3S+BEAR]
Napsal : 28/09/2021 7:19 pm
heatbreak
Just replace it.  Not worth your time unless you print just PLA.
Posted by: @gepstra
Napsal : 29/09/2021 1:31 am
Gepstra
(@gepstra)
heatbreak
Yeah I still have one from the original Prusa Mini, so that's at least a little bit better than this one. I'll look for a Bondtech clone or a real Bondtech one later. Hotend also does not look that good as you said.
Napsal : 29/09/2021 11:39 am
Urshurak776
(@urshurak776)
Heat Break
Weird. Mine came with a new style heatbreak that looks like the bondtech. Where did you buy your clone?  I got mine from the official FYSETC AliExpress store.
Napsal : 29/09/2021 6:47 pm
Gepstra
(@gepstra)
Store
I didn't get it from the official store so that might be why. May be good to know for others.
Napsal : 29/09/2021 6:51 pm
Gepstra
(@gepstra)
Impressions
Well after fixing a clogging issue with the PTFE coupler on the hotend side I have it running pretty much stock with only the original Minda sensor from my Original Mini and the original heat break. It's printing beautifully even though I probably shorted the hotend fan (waiting for a replacement), it runs at half speed now I'm guessing. Bearings are pretty shite and loud. Heatbed is a little slower to warm up.
Pretty happy with it and it's not going to be long until it's earned itself back printing rockets 🙂🚀
Napsal : 27/10/2021 5:30 pm
PTFE coupler
I use a PTFE coupler also to ease unloading.  I hate the current setup.
Napsal : 27/10/2021 6:36 pm
Gepstra
(@gepstra)
PTFE coupler
Push fittings
These ones, they ruin the PTFE as well.
Napsal : 27/10/2021 6:41 pm
Couplers
I misunderstood.  I use a coupler to track two pieces of PFTE.
Napsal : 27/10/2021 6:50 pm
Turro75
(@turro75)
RE: Prusa mini Fysetc clone - log of a journey
Hi All,
I recompiled 5.1.0 beta inputshaper with some fix for using it with fystec clones:
  1. extended x-axis length from 188 to 190mm as on my clone selftest failed due to that
  2. enabled PID autotune (M303 working for hotend and bed)
  3. enabled skew correction (M852)
  4. disabled screen flashing every 2secs
  5. set the hotend thermistor type to 1 instead of 5
  6. increased the hotend fan speed from <3000rpm to 4500rpm
Napsal : 25/11/2023 11:25 pm
1 lidem se líbí
Capran
(@capran)
WOW! Thanks so much for this @Turro75! This worked perfectly for my 2 Fysetc clones!
Napsal : 27/11/2023 1:59 pm
Turro75
(@turro75)
This is the same but based on stable 5.1.0, it is the EN-IT build.
Napsal : 27/11/2023 3:23 pm
2 lidem se líbí
Riko
 Riko
(@riko)
Hello,
would it be possible to modify the en-cs configuration in this way?
Napsal : 27/11/2023 8:47 pm
Turro75
(@turro75)
All available languages
Napsal : 28/11/2023 6:03 pm
2 lidem se líbí
Riko
 Riko
(@riko)
thank you very much
Napsal : 28/11/2023 8:13 pm
Jonn77
(@jonn77)
Hello, I have been able to solve the screen problem, but the Spanish language does not appear, do you know how to solve it? I have copied all the files and the option in Spanish does not appear
Napsal : 01/12/2023 10:27 pm
Jonn77
(@jonn77)
Posted by: @turro75
Napsal : 01/12/2023 10:36 pm
adp97
(@adp97)
Thank you for sharing this! No more flickering and it works fine
Napsal : 02/12/2023 11:18 am
Stránka 6 / 9
