Print head nearly parks on the print bed
All of a sudden my print head, when finishing a print, moves to the upper left of the print bed and lowers itself almost all the way the print bed making it hard to remove my prints. I have to slide the print bed forward until it clears and I can lift it. This almost seems like a print setting, but 1. I am not able to find that setting and 2. I have not changed anything, I have only updated my prusa slicer to the most recent version. Any help would be appreciated.
RE: Print head nearly parks on the print bed
Update the firmware. This is a well known incompatibility between the versions of slicer and firmware you're running.
Great, thank you. I did update the firmware before this post thinking that might be it, but had not run a print job since. I thought I might drop this in before just incase there was something else I needed to do. Will give it a shot, thank you so much for the fast reply.
Ran a print and it parked out of the way as expected. Thank you again
