[Rozwiązany] Octoprint with raspberry pi zero 2 w
upperairs
(@upperairs)
The title says it all. I tried it with the raspberry pi zero 2 w and the mini+ was not detected. Does anyone have a reliable guide on getting this to work? Thanks.
Opublikowany : 13/09/2022 7:10 pm
bshiro
(@bshiro)
RE: Octoprint with raspberry pi zero 2 w
not knowing anything about your setup, my first questions would be, how are you connected?  are you using an OTG cable?  I am new to Octoprint, but I thought is should be pretty much plug and play if the hardware is all plugged in correctly.
Opublikowany : 14/09/2022 1:02 am
upperairs
(@upperairs)
Update: I changed the OTG cable for another one that I had and it worked right away. The old cable still works fine on my ender 3 on octoprint.
Opublikowany : 14/09/2022 3:08 pm
