OctoPrint external USB camera feed goes away - fix included
Daryl
(@daryl-2)
I use an external, USB connected webcam to monitor a Prusa Mini via Octoprint.  Every once in a while the video feed in Octoprint goes away.  Rather than have to reboot the RPi, the following command always fixes the issue even when in the middle of a print:
sudo service webcamd restart
You do need terminal access via ssh, VNC, local keyboard and monitor, etc.
Currently running v1.5.3 Octoprint on a RPi 3B+
Napsal : 10/04/2021 6:17 pm
cwbullet se líbí
John Doe
(@john-doe-3)
RE: OctoPrint external USB camera feed goes away - fix included
I would recommend to check this page:
https://elinux.org/RPi_USB_Webcams
Some webcameras connected via USB may be problematic, like high power-output or peaks, bad drivers etc...
I have one Microsoft camera, that had power-peaks, that even raspberry deemed them once a while as faulty. Reboot was necessary
Napsal : 12/04/2021 6:13 am
Daryl se líbí
Posted by: @daryl-2
I will give this a try tonight.  I have one that is a little finicky.
Napsal : 12/04/2021 10:48 am
