Keep Mini on and connected, but no heat?
lnjustin
(@lnjustin)
I've got my new Prusa Mini+ set up with OctoPrint on a raspberry pi and connected to my smart home, as well as using Obico. I also have a smart plug controlling power to the printer, where the smart plug shuts off power if a smart smoke detector is triggered. Problem is that when I am not printing, I have been cutting power to the printer. And of course cutting power to the printer disconnects the raspberry pi from the printer. Questions:
(1) is there a way to keep the Prusa Mini+ powered on, so as to retain connection to OctoPrint, while shutting everything else off (heat, etc.) when not printing?
(2) is it a good idea to do that? Safety-wise and otherwise? Is this a typical thing that people do?
Publié : 05/01/2023 2:19 pm
lnjustin
(@lnjustin)
As an example, could I just put use the below gcode for after a print job completes? This is the same as what Octoprint has as the default gcode script to execute after a print job is cancelled. Would this shutdown everything but the connection to Octoprint, and keep the printer in a safe state when not printing?
; disable motors
M84
;disable all heaters
{% snippet 'disable_hotends' %}
{% snippet 'disable_bed' %}
;disable fan
M106 S0
Publié : 05/01/2023 2:33 pm
RE: Keep Mini on and connected, but no heat?
Out of curiosity, what's wrong in your mind with just shutting it off? That's what I do, shut my Minis off while leaving the Pis running.
Publié : 05/01/2023 2:52 pm
lnjustin
(@lnjustin)
Disconnection stops updating the temperature readings so that my smart home no longer knows the temperatures. It also bothers me that Octoprint indicates the printer's state as "offline after error". There's no error! It's a small quibble, though, so mostly just interested in doing this if it's a practice that is common, acceptable, and safe.
Publié : 05/01/2023 3:04 pm
Note - I dont have a mini but.....
When you slice a file for the mini with the default profiles then those do turn off the extruder and bed heating as well as the part fan.  So it already does what you want.  No need to add anything to octoprint, the commands are in the sliced file you are sending to the printer.
There is no need to power the printer off after a print.  On the MK3 in fact doing so is not recommended, this is because the hotend fan normally is controlled by firmware and will carry on working until it drops below a certain temperature (around 50 degrees) and then the firmware turns that off itself.  I should imagine the mini is the same.
If you just power off immediately without letting it cool down then the heat will work its way up the extruder (in effect generating heat creep) and could cause problems on the next print as the filament would have been partially melted while sat there in an area thats normally 'cold'.
It's quite normal for a print to finish middle of the night and for it to sit there afterwards for hours before being attended to in the morning.
Publié : 05/01/2023 3:11 pm
lnjustin a aimé
I don't see any safety issue. My printers are pretty much on all the time. And I don't even have a separate smoke detector for the printer beyond the standard ones across the house. As neophyl said, standard print profiles turn hotend and bed off, and there's a safety timer in firmware that turns off heat after a period of time (eg after loading or unloading filament)
Publié : 05/01/2023 3:16 pm
lnjustin a aimé
lnjustin
(@lnjustin)
Would there be any issue in including the above gcode scripts in Octoprint as a safeguard? I'm thinking about a scenario where I print a gcode file downloaded from Printables, without necessarily knowing whether the gcode was modified to exclude those commands?
Publié : 05/01/2023 3:33 pm
I guess why not but then again the whole notion of downloading gcode files is not something I can condone. The only exception I can come up with is the Prusa belt tension meter because for inexcusable reasons they do not provide a 3mf or STL file. Beyond that you should always reslice for your specific printer and filament because more likely than not the downloadable  gcode is not optimized for that particular combination. If an author feels the need to communicate specific settings for a print they should do that through a 3mf file.
Publié : 05/01/2023 3:51 pm
lnjustin
(@lnjustin)
Good to know. Makes sense. Thanks!
Publié : 05/01/2023 3:53 pm
