Is power module for the Mini senstive to heat?
Hello,
I want to put the Mini in an enclosure. It is okay to leave the powersupply and controller within the enclosure? I have not seen any requirements to mount it external to the enclosure.
Thank you
Patrick
Postato : 12/09/2023 4:13 pm
RE: Is power module for the Mini senstive to heat?
Every PSU is sensitive too heat. It will work within reasonable temperatures but you will shorten the life span of the PSU. The hotter it is the shorter the life span.
Some people keep the PSU inside the enclosure, some mount it outside.
Postato : 13/09/2023 11:09 am
