[Résolu] Intro line printing off the plate
Page 1 / 2
Alter3go
(@alter3go)
I have fitted a Phaetus Dragonfly HIC hotend.
Everything is fine, except the Intro line prints off the sheet. Obviously the Nozzle's Y position changed.
I have tried setting the offset with M206 Y-4, for example, but that doesnt change, even if I set it to Y-1.
Where/how can I set the correct offset for the new Nozzle?
Publié : 18/04/2022 6:15 pm
1 personnes ont aimé
RE: Intro line printing off the plate
Can you post your startup gcode? M206 should do the trick.
Publié : 19/04/2022 2:34 am
junkmonkey
(@junkmonkey)
I'm also interested in this, I feel like my printer believes it's X axis is about 5mm to the left of where it actually is.
Publié : 19/04/2022 3:12 pm
Alter3go
(@alter3go)
M862.3 P "[printer_model]" ; printer model check
M83 ; extruder relative mode
M104 S170 ; set extruder temp for bed leveling
M140 S[first_layer_bed_temperature] ; set bed temp
M109 R170 ; wait for bed leveling temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M204 T1250 ; set travel acceleration
G28 ; home all without mesh bed level
G29 ; mesh bed leveling
M206 Y-5
M204 T[machine_max_acceleration_travel] ; restore travel acceleration
M104 S[first_layer_temperature] ; set extruder temp
G92 E0G1 Y-2 X179 F2400
G1 Z3 F720M109 S[first_layer_temperature] ; wait for extruder temp
; intro line
G1 X170 F1000G1 Z0.2 F720G1 X110 E8 F900G1 X40 E10 F700G92 E0
Publié : 19/04/2022 3:34 pm
Alter3go
(@alter3go)
doesnt matter what value I use, the intro line keeps printing just about 1mm off the bed
Publié : 19/04/2022 3:35 pm
This may be the culprit.
It should be
G92 E0
G1 Y-2 X179 F2400
Without the G1 line, your nozzle never moves to the proper place.
Publié : 19/04/2022 8:44 pm
2 personnes ont aimé
Alter3go
(@alter3go)
sorry, that was my mistake. After pasting the code here, I had to move each command to a new line, and obviously missed that one.
In PrusaSlicer it is as you suggested.
G92 E0
G1 Y-2 X179 F2400
could that G1 Y-2 be that is countering my M206 tho?
Publié : 20/04/2022 6:28 am
Alter3go
(@alter3go)
ok, will do that when I get home, thanks
Publié : 20/04/2022 6:29 am
Alter3go
(@alter3go)
I changed that Y value from -2 to -5 .. still draws the line at the same place
Publié : 20/04/2022 1:57 pm
Okay, time to post a 3mf project file. It contains all your settings so someone can do a test print to try and replicate the issue.
In Prusaslicer, go to File/Save project as, to create the 3mf file. Zip compress it (right click Compress on Mac and Win11, right click Send to/Compress on Win10) to turn it into a .zip file, which you can attach to a post on this forum. The forum software does not accept .3mf files, it has to be a .zip file.
Publié : 20/04/2022 2:24 pm
Alter3go
(@alter3go)
The picture shows the preview of the gcode, I have marked with the red line where about my intro line prints
Publié : 20/04/2022 4:59 pm
Alter3go
(@alter3go)
gcode file
Hi, thanks but I have no desire to dig through gcode. Please post the 3mf project file as I described above, much easier to check on settings that way.
Publié : 20/04/2022 6:00 pm
Of course I couldn't resist. I went into my own copy of Prusaslicer and lo and behold I can't see any changes either when I try to use M206 to adjust the printer's coordinate system. So maybe the Mini doesn't support M206.
In any case, you should be able to accomplish what you're trying to do by simply changing
G1 Y-2 X179 F2400
to something like
G1 Y-1 X179 F2400
You may have to play with the Y parameter to get it right but this works for me and should get your Y line back onto the steel sheet.
Publié : 20/04/2022 6:16 pm
Alter3go
(@alter3go)
gosh, sorry, I was reading one thing, and did something completely opposite .. sorry about that
Publié : 21/04/2022 2:21 am
kevman
(@kevman)
are you using Octoprint ? You have to specify a custom bounding box in Octoprint, I had a similar issue and that was something I had to change. See article below
https://help.prusa3d.com/article/octoprint-configuration-and-install_2182
Publié : 21/04/2022 5:53 pm
Zoltan
(@zoltan)
Membre Moderator
@alter3go
When you do homing, is the print head positioned correctly?
Then you go to settings->move axis and elaborate with y. You will find the position, where you need to move y for intro line.
Publié : 22/04/2022 3:20 pm
Alter3go
(@alter3go)
this fixed the issue, but I think the reason why initially there was no change, was because I was going Y-3/-4/-5 and so on, instead of changing the value positively.
from Y-2 to Y2 fixed the problem
Publié : 23/04/2022 9:56 am
Happy yo hear that you found the solution!
Publié : 23/04/2022 10:40 am
prongato
(@prongato)
Thank you so much for this!  I had the same issue and after I changed the hotend to a Revo Micro yesterday, it’s off the front edge completely.  It was driving me crazy!  It does suck that I’ll have to re-slice a lot of files I already sliced on my Octopi but at least I have the solution!
Posted by: @alter3go
Publié : 20/11/2022 8:49 pm
Page 1 / 2
