Hardened steel nozzle and abrasive filaments
Chriffe
(@chriffe)
I was looking at this interview that Thomas Sanladerer did with Josef Prusa about the Prusa Mini. At 12:15 in the video they talk about the hotend. Am I understanding it correctly that it should be possible to mount a hardened steel nozzle to it and print abrasive materials? I have got a hardened steel Micro Swiss E3D V5-V6 compatible nozzle that I am thinking of using.
Napsal : 15/01/2020 9:47 am
Lichtjaeger
(@lichtjaeger)
RE: Hardened steel nozzle and abrasive filaments
I'm using a 0.25 Nozzle X without problems.
Napsal : 15/01/2020 4:18 pm
Koen Kooi
(@koen-kooi)
Same here, 0.25mm Nozzle X without issues.
Napsal : 17/01/2020 10:36 am
Steve Smith
(@steve-smith)
I was just about to search for Nozzle X compatibility, Glad I can use it with the Mini
My Mini has: A SuperPINDA + Bondtech Heatbreak + Bondtech Extruder installed
Napsal : 26/02/2020 3:32 pm
Just keep in mind that the Nozzle-X is essentially just a hardened steel nozzle with a coating and rated to higher than normal temps. It doesn't have the same thermal characteristics as brass. Great if you're printing at high temps (higher than you can on a Mini). If not, there are cheaper alternatives. Don't own a Mini myself yet, but I'd try P3-D's Apollo coated nozzles for non-abrasives, or Hercules for abrasives.
Napsal : 26/02/2020 4:52 pm
Please be aware that there are many abrasive filaments,
those without particles incorporated in the filament (Say Glow in the Dark filament) will work with a 0.25mm nozzle...
BUT those like Carbon Fibre re enforced filament, will clog in small nozzles...
some folk have problems with carbon fibre filament in 0.4mm nozzles...   I got hardened 0.6mm nozzles for Carbon Fibre!
Typically hardened nozzles need slightly raised temperatures, compared to the same filament with Brass nozzles.
I don't plan to switch between hardened and brass on a regular basis, unless I am also changing nozzle size.
Napsal : 26/02/2020 4:59 pm
3 lidem se líbí
Steve Smith
(@steve-smith)
Posted by: @joantabb
Good Advice, I wasnt aware of this.. I will make sure I have different nozzles depending on what I intend on printing with.
I want to print with a mixture of filaments, I take it if you use something like a Palette 2 and mix filament types its better to go with the bigger nozzle to be on the safe side
Napsal : 26/02/2020 5:06 pm
