Different Hotends
Stránka 11 / 16
GrimmWinters
(@grimmwinters)
RE: Different Hotends
After playing with the settings to get a weird banding in y-axis resolved, i figured, going through the initial calibration again might help and it did.
Now i have a mini on steroids, running with the bowden extruder and a copperhead hotend assembly. yesterday i was able to do my first 6 hour print without any problems. took some time and money but now it's the machine i hoped for when i ordered it.
Napsal : 29/09/2020 9:02 am
It mostly depends on what material you print with. With PLA, PETG and the like there will probably be no problems with the standard hotend. The first problems came up when I tried to print XT-CF20. The original hotend tended to get clogged and sometimes the compression fittings came loose. The E3D V6 hotend was and still is the cheapest functional solution for me.
The MK3 doesn't mind helping out its small brother with spare parts.
Napsal : 29/09/2020 10:03 am
kevman
(@kevman)
@karl-herbert
I had problems with Prusament PLA, any print over 40-45 mins would clog. Perpetual heat creep is my guess.
Napsal : 29/09/2020 1:40 pm
@kevman
Do you print in an enclosure or are the ambient temperatures too high? Maybe the extruder motor is getting too hot. In this case, you can actively cool it with a 40x40mm fan.
Napsal : 29/09/2020 4:00 pm
GrimmWinters
(@grimmwinters)
@kevman had the exact same problem with prusament galaxy black. extruder started clicking after a while and then just a big blob above the hotend. i didn't try that filament in my new setup yet. will tell, if it works now.
Napsal : 29/09/2020 4:39 pm
Zoltan
(@zoltan-d-2)
Member Moderator
Posted by: @kevman
@karl-herbert
Hi can you please provide details?
Napsal : 29/09/2020 7:42 pm
rockytoptim
(@rockytoptim)
You guys with the Mosquito are you see any print time improvements?  Thinking of going Mosquito route and was just wondering.  Its not top priority but would be a bonus to the reliability i expect to get from the Mosquito.
Napsal : 07/11/2020 8:19 am
4nthonylin
(@4nthonylin)
Posted by: @rockytoptim
@rockytoptim
The main reason I believe for the mosquito upgrade is for an increase in reliability and better support for high temperature filaments. I have not tried pushing my printer to go faster although that's certainly something you can investigate.
Napsal : 07/11/2020 10:58 pm
@rockytoptim
The plus to the mosquito in my book is higher temperature printing.
Napsal : 08/11/2020 1:41 pm
kevman
(@kevman)
I'm about to installed @4nthonylin shroud and cooling duct mod. Any tips for installation ? Also anyone have pics of the process and final assembly ?
Napsal : 15/12/2020 8:49 pm
I am setting up one of my mini's with an easy change tool setup.  The goal is to swap hotends in 5-10 minutes or less.
Napsal : 16/12/2020 3:26 am
4nthonylin
(@4nthonylin)
@kevman
You can mostly follow these instructions: Prusa Knowledge Base | How to replace a heatsink (MINI) (prusa3d.com) for disassembling the hotend heatsink. For the x-carriage for the cooling, you will have to remove the end which should just be two screws and popping out. Then pulling out the belt from the x-carriage. Let me know if you have any questions however don't have a full guide with pictures made.
Best of luck!
Napsal : 16/12/2020 3:35 am
3Dprintedgr
(@3dprintedgr)
Posted by: @karl-herbert
Karl what material did you use for the E3D V6 bracket? It will not touch any hot parts so I guess it could be printed with PETG?
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Napsal : 16/12/2020 12:45 pm
@3dprintedgr
I reprinted all the printerparts of the Mini with ASA Durapro. So far, I have not experienced any problems with melted or broken printed parts.
Napsal : 16/12/2020 2:03 pm
1 lidem se líbí
3Dprintedgr
(@3dprintedgr)
@karl-herbert
Hmm, ok did you use an MK3s to print the parts? I am asking because I only have the MINI and haven't tried ASA yet on it.
Prusa Slicer 2.6.0
Napsal : 16/12/2020 2:14 pm
@karl-herbert
I used ASA and PC Blend for parts.  Same results.
Napsal : 16/12/2020 2:22 pm
@3dprintedgr
The mini will print ASA.
Napsal : 16/12/2020 2:23 pm
1 lidem se líbí
@3dprintedgr
Printing ASA is possible with the Mini without any problems. I print almost exclusively ABS and ASA with it. The Mini practically printed itself.
Napsal : 16/12/2020 2:46 pm
1 lidem se líbí
3Dprintedgr
(@3dprintedgr)
@cwbullet
I have seen the specifications but for some reason I was afraid to try even though I always wanted to. Maybe because I don't have an enclosure and the temperature of the room that the printer is located is around 22C to 23C. I will order one and will try the tips from Prusa posts(custom skirts) and see how it works. Any other tips that you recommend?
Prusa Slicer 2.6.0
Napsal : 16/12/2020 3:07 pm
kevman
(@kevman)
Posted by: @4nthonylin
@kevman
Best of luck!
Thanks so much!! Did you print with supports ?  I'm planning on printing the parts out tonight.
Napsal : 17/12/2020 7:56 pm
Stránka 11 / 16
