Cura 5.0 Prusa Mini
Hello
Is someone able to assist in configuring the Prusa mini in the new cura 5.0beta
I'm happy to pay for someone to get this setup and dialled in.
TIA
RE: Cura 5.0 Prusa Mini
Hi
In my case I just used the Cura 4.0 profile which is provided by Prusa, and it works just fine. You surely have to play around with the new settings, as they aren't finetuned by Prusa yet but I was able to print just fine.
https://help.prusa3d.com/guide/wie-man-profile-in-cura-4-x-importiert-windows-macos_17848
Happy printing! 😉
I have installed it for MAC and the mini did not show. I'll confirm the install and also on windows
I managed to install the mini profiles into cura for windows today, but it lists it under "Prusa Research" and not "prusa3D".
@printer-mcgee
As @eightyeight said already, you should be able to find the profile in the "Prusa Research" tab. If you don't have it, could you please provide some screenshots of your Cura installation?
Instructions for the 4.0 install are the same with the exception fo the folder location. On Windows 10, the resources location has moved for me. With the cura 5.0 update it is in: "C:\Program Files\Ultimaker Cura 5.0.0\share\cura\resources"
