Can’t connect Prusa Mini to Prusaprint
Hello I cannot connect my Mini to prusaprint. I’m using a powered raspberry pi zero W. All I’m using it for is the bed leveling mod. It’s connected to the Micro usb and can’t recognize it. It worked fine for setting the bed up with the i3 but no luck with the mini
Publié : 07/09/2021 6:08 pm
Try this, it help me
(IMPORTANT - Genuine USB cable)
Maby this will help
In Octoprint serial settings, leave Serial Port and Baudrate on Auto and leave Additional serial ports field blank, and enable Request exclusive access to the serial port
Publié : 08/09/2021 8:01 am
Another suggestion
Do you mean Octoprint? Which USB port on the Mini are you using? You need to be using the micro-USB one.
Publié : 08/09/2021 7:31 pm
