Anyone use the new Raspberry Pi camera HQ
rockytoptim
(@rockytoptim)
Just wondering if anyone has used the new raspberry pi camera HQ for monitoring prints or octolapse.  If so is it worth the $75 ($50 for cam $25 for wide angle lens)?
Respondido : 19/10/2020 5:12 am
Clemens M.
(@clemens-m)
RE: Anyone use the new Raspberry Pi camera HQ
Maybe worth if you are thinking about permanent octolapse use. Just for monitoring I use a cheap clone of the RaspiCam with 5MP and that is absolutely enough.
Best regards, Clemens
Respondido : 19/10/2020 5:47 am
adesir
(@adesir)
Something like that: https://notenoughtech.com/3dprint/octolapses-using-raspberry-pi-hq-camera/ ?
Mes modeles publics
Respondido : 19/10/2020 7:11 am
Steve
(@steve-4)
I use the stock Pi 5MP camera and it works fine for me.
Senior Life member of IEEE.
Respondido : 04/12/2020 9:03 pm
d0ug
 d0ug
(@d0ug)
I have one of the Pi HQ cameras. The image quality from is is VERY good, but I have not tried using it for octoprint. I run octoprint on a Pi Zero W. which is perfectly fine for remote/network printing, but almost certainly wouldn't support something like octolapse. I picked up my HQ camera to use as a USB webcam. This video will show you the quality of them as well
Respondido : 04/12/2020 10:35 pm
jsw
 jsw
(@jsw)
Same here, I've used the stock RPI Cam module for a few projects, but never the HQ version.  I figure if I really need HQ, I'll use a more traditional camera.  The stock RPI Cam actually produces pretty fair photos. I say better than many phones and certainly better than many of the 'last generation' P&S digital cameras.
Here's a 'spy cam' I made a while back.  PI Zero, Cam module, battery and little power/charger board.
(And if you are observant and noticed that the texture on the printed part does not look like Prusa, you're right.  It was done on a Uprint at the local 'makerspace' a couple years ago.)
Respondido : 04/12/2020 10:42 pm
2 les gusta
Steve
(@steve-4)
I can't see any benefit to an HQ camera for Octoprint, but I suppose it depends on what you want.  I use the camera mainly for seeing if the printer is printing correct and that the item I am printing has stuck to the bed.  If you want to make high resolution movies of your printing, great.  I would personally be bored to tears.  Sort of like watching grass grow.
In any case, I wouldn't put any money into a better camera.  I have other areas where I would spend more money such as an enclosure or a better all-metal hotend, although I don't need either right now.
Here's what I did with my printer and Octoprint:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../new-600w-power-supply-octoprint-mods/
Respondido : 04/12/2020 10:56 pm
Clemens M.
(@clemens-m)
Posted by: @jsw
Nice project - do you have some further information about that? How long is that running on the battery?
Respondido : 05/12/2020 11:34 am
Clemens M.
(@clemens-m)
Is the blue board for charging the battery - some kind of adafruit board or something similar?
Respondido : 05/12/2020 11:44 am
jsw
 jsw
(@jsw)
The 'spy cam' was one project that was being passed around at the local 'makerspace' a while back.  I should have the .stl files somewhere, but I may or may not be able to find them easily.  If you want them I'll try to look.  I made a few tweaks to the project, one was a hollow cylinder on the rear, above the clip, for holding a shoelace lanyard to wear around the neck.  Another was to add a simple 'mount' for a generic wide-angle adapter lens.
The code that I used is trivial.  Just a 'forever' loop in a shell script to take a photo, store it, wait a while, sync the file system, rinse, repeat.  It's also possible to log in to the thing via a cell phone and manually take photos.
It runs a few hours on one charge.
Yes, the blue board is from Adafruit.  It's one of the 'Power Boost' series.  There are a number of similar products in the series, some with a charger, others which only power the project from an already-charged battery.  IIRC the one pictured is the PB 500C.  It will efficiently boost the voltage from a common 3.7v battery to 5 volts for the project.  They are not cheap, but still reasonable.  Here's a link to the first similar one I found this morning:
https://www.adafruit.com/product/2465
Another very handy similar item, if you do Pi Zero projects is their 'buck converter' which is indeed small and cheap and converts 6-21v from a battery or DC supply to 5v for the project without wasting power or producing (much) heat, as you would get with a simpler 7805 type regulator.
https://www.adafruit.com/product/4739
Respondido : 05/12/2020 2:10 pm
Steve
(@steve-4)
I use these puppys:
https://www.amazon.com/gp/product/B01HXU1C6U/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I just take off the USB connector and wire them in.  I use them for running big PIs off 24 V or 12V.  They work great.  MUCH cheaper than Adafruit.
The PIs have a buck converter on board to take the 5V and convert it to 3.3V for the processor.
Respondido : 05/12/2020 3:44 pm
AnnieR
(@annier)
That kinda looks like the Canon Ivy Rec sports camera.
Respondido : 05/12/2020 5:27 pm
