Anyone have successful Octolapse settings?
Page 3 / 3
Gordon W
(@gordon-w)
RE: Anyone have successful Octolapse settings?
Have you looked at this: https://github.com/FormerLurker/Octolapse/wiki/V0.4---Troubleshooting-Print-Quality-Issues
Posted : 10/11/2020 1:16 pm
DangeMask
(@dangemask)
@gordon-w
Thank you, this manual can help. There are a few points I already considered like "Try the Smart - Snap To Print trigger type", but right now, I have camera mounted to the top of the printer (planning to switch to tripod), so the only good looking stabilization was "Back center".
A soon as I get the new camera angle, I'll try to change triggers and stabilization for more experience
Posted : 10/11/2020 1:34 pm
Boondocks846
(@boondocks846)
By@ss220
Wow your prints are so amazing! I just posed a topic about straining and I was curious what you did to get such clean prints? Did you ever have straining issues?
My topic: https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/cant-stop-the-stringing/
Posted : 16/02/2021 3:18 pm
SS220
(@ss220)
Cute Octolapse of Baby Dragon 3
Just another time lapse on the Mini. Baby Dragon 3 by PrintNPaint Miniatures.
Posted : 19/09/2021 11:00 pm
b1naryv1k1ng
(@b1naryv1k1ng)
Just starting using Octolapse today and on my test print of a benchy, there seems to be a huge delay between each layer. I'm using centered stabilization and it seems to sit for almost a minute each time it goes to take a time lapse photo. It is causing what should have been a just under 2 hour print to be a 7+ hour print.
Octoprint Version 1.7.3
Octolapse Version 0.4.1
Prusa Mini+ Printer
I'm using the built in Prusa Mini profile in octolapse. Octoprint is running in a docker container. Anyone have any suggestions on what might be the cause of this huge delay?
Posted : 27/02/2022 4:01 am
b1naryv1k1ng
(@b1naryv1k1ng)
I forgot to add, when I looked at the terminal during one of the delays this is what I see:
Send: N152642 G1 Z0.200 F9.000*9
Recv: ok
Send: N152643 G90*39
Recv: ok
Send: N152644 G0 X90.000 Y89.000*16
Recv: ok
Send: N152645 M400*22
Recv:  T:215.26 /215.00 B:59.97 /60.00 A:46.04 /0.00 @:75 B@:32
Recv: echo:busy: processing
Recv:  T:215.16 /215.00 B:60.07 /60.00 A:45.95 /0.00 @:74 B@:21
Recv:  T:215.00 /215.00 B:60.03 /60.00 A:45.98 /0.00 @:75 B@:25
Recv:  T:214.58 /215.00 B:60.03 /60.00 A:46.04 /0.00 @:78 B@:26
Recv:  T:214.32 /215.00 B:60.02 /60.00 A:46.04 /0.00 @:80 B@:27
Recv:  T:214.22 /215.00 B:60.00 /60.00 A:46.04 /0.00 @:80 B@:29
Recv: ok
Send: N152646 M114*21
Recv: X:90.00 Y:89.00 Z:39.10 E:3.53 Count X:9040 Y:8900 Z:15688
Recv: ok
Send: N152647 G0 X88.529 Y89.118*28
Recv: ok
Send: N152648 G91*45
Recv: ok
Send: N152649 G1 Z-0.200*110
Recv: ok
Send: N152650 G1 E3.20000 F2400.000*41
Recv: ok
Send: N152651 G90*36
Recv: ok
Send: N152652 M83*47
Recv: ok
Send: N152653 G1 X91.975 Y92.564 E.11294*100
Recv: ok
Send: N152654 G1 X91.973 Y93.087 E.01212*99
Recv: ok
Send: N152655 G1 X88.138 Y89.253 E.12567*106
Recv: ok
Send: N152656 G1 X87.732 Y89.371 E.00982*111
Recv: ok
Posted : 27/02/2022 4:08 am
SirPalinDrome
(@sirpalindrome)
Did you ever figure this out?  I am seeing the same issue.
Posted : 21/03/2023 2:06 am
JoHnEyAp
(@johneyap)
I did, but for a mk3s with mmu2s, it would jam constantly at the end of a print on the unload.  The fix is not to use the smart triggers, as far as I can tell, they are causing my issue by ramming the tip too much, this happens on single material prints too.  Not to mention the artifacts.
switch to classic gcode mode and tick the box for z hop only, if you are using prusas slicer, z hop after retract is enabled by default and so is retract after layer change.  I'm still fine tuning the remaining settings to get it even better, ill probably make an updated video as the ones out their don't work well anymore.
its worth noting, any stabilization works now and doesn't leave artifacts, teaching techs video is where I figured this out, he doesn't explain it, but I paused every second of that video and combed the settings he had.
TLDR: Take off smart compatibility, turn on classic gcode, edit the profile, tick the box that says on trigger on z hop only.
you can use snap @octolapse take-snap or g4 p1, they are all enabled by default(double check i spelt them right first) put one of these in at the after layer change gcode in your slicer
enjoy your timelapse!
This post was modified 1 year ago 4 times by JoHnEyAp
Posted : 18/07/2023 6:35 am
haresh
(@haresh)
I would like to know how to optimally set up OctoLapse for my Prusa i3 MKS+.
Do you think you may be able to assist?
Thank you kindy, in advance
Posted : 24/12/2023 5:17 am
haresh
(@haresh)
Posted by: @bradmcgonigle
@formerlurker I opened a ticket but let me know if you need any more details.  I'd be happy to provide whatever you need or run some tests for you. https://github.com/FormerLurker/Octolapse/issues/462
Posted : 24/12/2023 5:21 am
Prof. Sanjiv Kumar Gupta
(@prof-sanjiv-kumar-gupta)
It is about proper settings in the octolapse printer profile. Go to printer profile, enable customize, Firmware settings, G90/G91 Influences Extruder (set it to true). it will solve the issue. Using this with the orca slicer, Ender 3 V2 neo.
I've been trying to get Octolapse working successfully with my Mini but can't get the settings right.  The nozzle keeps getting blocked after the first layer no matter what 'Stabilization' setting I use.
Posted : 02/07/2024 6:31 pm
Page 3 / 3
