1st layer calib with .6mm hardnd noz
Renn
 Renn
(@renn)
Switched to a .6mm nozzle and tried to calibrate with PETG. Started with same settings as .4mm nozzle and it started to curl. The first line was OK but when it started with the zig zag pattern the lines lifted and curled around the nozzle. No matter what setting the filament starts to curl. started with 0 and then progressed closer with no luck. Is there a hardware setting on the mini to tell it that it has a .6mm nozzle? I read that the first layer calib is meant for use with a .4mm
Thanks!
Best Answer by JoanTabb:
You need to re slice a test file with the 0.6mm nozzle setting, and then do a live Z calibration.
try the attached file, it should give you a 75mm square test file, one layer thick!
regards Joan75mm square_0.6n_0.2mm_PLA_MINI_9m
Publié : 25/12/2020 3:08 am
RE: 1st layer calib with .6mm hardnd noz
Publié : 25/12/2020 11:09 am
1 personnes ont aimé
Renn
 Renn
(@renn)
@joantabb
Just wanted to say mahalo (thank you) from Hawaii. That was the solution.
Publié : 26/12/2020 12:23 am
@renn
Excellent,
I hope you enjoy your Prusa Experience!
Joan
Publié : 26/12/2020 1:55 am
