0,5mm nozzle profile?
Zeropoint
(@zeropoint-2)
Hi all. Just changed the nozzle to 0,5mm, can't seem to find a profile for it. It is odd Prusa doesn't include the profile in the slicer, since I've bought the 0,5mm and 0,6mm nozzles along with the Mini, and I really don't want to do any guesswork for the 0,5mm... what settings do I use and is there a profile available somewhere?
Also, as per instructions on youtube, when I've slightly loosened the hotend, just by a few degrees, the thermal alarm went off, then I just unscrewed the nozzle, turned the machine off and on and reheated, put the nozzle back and tightened the hotend. Seems to be fine, and I'm printing a test benchy. I'm a little scared that I've moved the thermo couple and that it's accuracy is now off. Should I not have loosened the hotend at all and all you need to do to switch nozzles is heat up, and unscrew the old one, screw-in the new one??
Veröffentlicht : 31/07/2021 9:50 am
BogdanH
(@bogdanh)
Posted by: @zeropoint-2
.. all you need to do to switch nozzles is heat up, and unscrew the old one, screw-in the new one??
-that's correct.
[Mini+] [MK3S+BEAR]
Veröffentlicht : 31/07/2021 1:01 pm
