Squash ball feet ?
Habony Norbert
(@habony-norbert)
Squash ball feet ?
My previous printer I3MK3S+ stood on squash ball legs, it worked very well, it made the printer quieter, etc.I'm also thinking about it for the MK4, but my question is how the alpha filmware (Input Shaper and Pressure Advance) will behave with these feet, will the vibration of the printer change?
Best Answer by Walter Layher:
I am using the squash ball mod on my MK4, but I have not yet done a comparison with and without the squash ball feet for printing with input shaping. I will do that as soon as the IS firmware is finished. The printer bounces a bit during IS prints but did not yet manage to leave the enclosure so far. 🙂 The feet I am using are interchangeable between the MK3 and the MK4 and you can simply take them off without tools. So far I have printed mostly without input shaping because the firmware is not very stable yet and for "normal" prints the noise reduction is very much worth using the mod. If you already have those for your MK3, just test them on your MK4. No harm done.
Posted : 28/06/2023 10:50 am
Thejiral
(@thejiral)
RE: Squash ball feet ?
For Pressure Advance it should not matter. Input Shaper on the other side could be impacted. I would just try it out. Print a input shaper test print before modifying the feet and print one afterwards. Then you know for sure what impact it has.
Posted : 28/06/2023 1:54 pm
Walter Layher
(@walter-layher)
Posted : 28/06/2023 2:59 pm
Habony Norbert
(@habony-norbert)
Thanks for the answer, I'm still waiting for the printer, thanks to the 10-week waiting period.I use a squash ball feet of my own design (it's above among the models on the printables page: https://www.printables.com/model/58399-squash-ball-feet).As soon as I have a chance, I will test my printer.
Posted : 28/06/2023 6:19 pm
Walter Layher
(@walter-layher)
Your version of the squashball feet should also be interchangeable between the MK3 and the MK4. The aluminum extrusions are the same on both. So you can test the ones you already have first.
Posted : 28/06/2023 10:08 pm
Rainer
(@rainer-2)
If such changes are made, I would recommend checking the frequencies for input shaper.
In my Treath I linked Gcode and instructions.
Just try it out. Also contributes better to understand input shaper.
Posted : 15/08/2023 11:11 am
UjinDesign
(@ujindesign)
@habony-norbert Did you ever get around to do a test with and without squash ball feet on the MK4 with input shaping? Please feel free to share your findings if you did!
Posted : 16/02/2025 7:50 pm
Habony Norbert
(@habony-norbert)
I haven't tested it without legs, I've been using it with legs from the first minute.It prints nicely, and I also bought the accelerometer.Compared to the factory settings, what the accelerometer measures is not significant. I don't think the legs affect the input shaping.
Posted : 18/02/2025 10:42 am
UjinDesign
(@ujindesign)
Posted by: @habony-norbert
When you say without legs, do you mean just placing the squash balls underneath the frame and letting it rest on them? I briefly tried that just for curiosity's sake, but that was a horrible idea, don't do that. The printer became way too unstable and produced strange printing artifacts. No artifacts that I can see either when using these feet! 🙂 Quiet as a mouse. The loudest thing is by far the fans (both on the printer itself and the air filter fan in the enclosure).
Posted : 18/02/2025 5:13 pm
Habony Norbert
(@habony-norbert)
Hi!
From the first minute I've only been using the ball feet, so I've never tested it with the original rubber feet.I started using the ball feet with the MK3 printer, it makes the printer much quieter.
I use these legs of my own design, they work for me.  https://www.printables.com/model/58399-prusa-mk3s-mk4-mk4s-squash-ball-feet
Posted : 19/02/2025 8:18 am
