Mk4 printed parts settings
EMarrs
(@emarrs)
What settings are you using to reprint parts? on my second mk3, I followed default settings. For my minis, I beefed it up with 30% honeycomb and an extra wall.
the mk4 doesn’t have an accelerometer, so I’m wondering if deviation will cause issues. I rarely use grid infill and typically aim for strongest infill type and % in functional parts.
I sliced all the mk4 parts in honeycomb 20% with everything else set to default. This seemed like a decent compromise between slightly stronger while not making parts considerably heavier or different.
Postato : 12/07/2023 11:11 am
RE: Mk4 printed parts settings
No idea. I printed everything in PC-CF, 3 perimeters 20% gyroid infill. In the process of putting everything together. The only issue so far is that the PC-CF doesn't have any flexibility so inserting the rods was a real pain. Personally, I don't care much for input shaping, not that I mind but for the functional stuff I print quality is a lot more important than speed.
Postato : 12/07/2023 5:37 pm
