Mk4 Enclosure possible modification..........
Dave M (NZ)
(@dave-m-nz)
Hi Folks,
   Has anyone looked at the possibility of putting the power box, main board box & front screen panel OUTSIDE the enclosure ?
Reason for asking is when the Mk4 printer is in the enclosure things get QUITE HOT, not very good for electronic components..... 😀
Publié : 31/10/2023 10:12 pm
James Kirk
(@james-kirk)
RE: Mk4 Enclosure possible modification..........
I have upgradedm from Mk3 to MK4 and I have the same setup like before.
That means, the power supply and the LCD is outside, the buddy-board is still inside.
But I have added an 80mm fan to the electronic box.
https://www.printables.com/model/580484-cover-for-adding-an-80-mm-noctua-fan-to-the-mk4-el/comments/1124537
Publié : 01/11/2023 10:12 am
Dave M (NZ)
(@dave-m-nz)
Hi, Nice job, but I was thinking on the lines of moving the boxes outside the enclosure with extension cables that could be quick disconnect so I can remove the Mk4 for any maintenance .......... 😀
Publié : 01/11/2023 8:34 pm
