LCD Screws
Sam
 Sam
(@sam-14)
LCD Screws
What size screws are on the LCD screen for the MK4
Respondido : 30/05/2023 11:27 pm
Walter Layher
(@walter-layher)
RE: LCD Screws
If you are looking for the necessary screws for mounting the display on the enclosure, in this model for a mount there are some screw sizes mentioned:
https://www.printables.com/de/model/448486-mk4-display-enclosure-spacer
I myself went with the "official" brackets from Prusa and used the screws that were used to mount the display to the printer. Unfortunately I did not make any notes about the sizes and I do not want to remove the display from the enclosure now. The less you remove the plug of the display cable from the display the better. I think the screws were M3x10, but I am not absolutely sure.
Respondido : 30/05/2023 11:48 pm
Sam
 Sam
(@sam-14)
RE: LCD Screws
No I mean the screws that hold the LCD assembly together. 2.5 hex key does not fit
Respondido : 31/05/2023 12:24 am
Walter Layher
(@walter-layher)
RE: LCD Screws
Ah, you mean the type of bit? A Torx T9 will fit.
Respondido : 31/05/2023 7:04 am
Walter Layher
(@walter-layher)
RE: LCD Screws
But it really is a Torx T10 pan head M3x10mm 🙂
Respondido : 31/05/2023 7:26 am
Sam
 Sam
(@sam-14)
RE: LCD Screws
Thanks, I think I need new glasses 😀
Respondido : 31/05/2023 11:15 am
vhubbard
(@vhubbard)
RE: LCD Screws
One of the two 90 degree torx wrenches in the kit has a different size on each end.  It caught me and I couldn't find the correct wrench,  until I carefully read the notes on the wrenches.
Respondido : 24/06/2023 2:36 pm
