        Extend Z axis on MK4
On the my prusa mini, there’s an experimental menu that allows the z axis to be extended:
https://help.prusa3d.com/article/experimental-menu-mini-mini_264396
Does anyone know if you can do the same on the Prusa MK4?
I’m thinking about buying a MK4 to replace my mini, but what I need to print is taller than the build volume of the MK4, so I was wondering about modding it. I’d probably do a bear mod, but with longer z axis. I was just wondering if I’d be into custom firmware, or if it could work without firmware changes like my mini.
thanks in advance
                            Posted : 04/09/2023 4:27 pm
