ESP32 Cam Support
Page 2 / 4
Ckobar
(@ckobar)
Again thanks for the help guys.
i made a little mount for mine. 🙂  with the programmers board attached.
https://www.printables.com/model/594659-arduino-cam-bal-magnetic-holder/files
Publié : 26/09/2023 12:47 pm
1 personnes ont aimé
Yasar
(@yasar)
@ckobar
do you also have a mount for the mk4?or where is yours attached?
Publié : 27/09/2023 6:14 am
Ckobar
(@ckobar)
RE: ESP32 Cam Support
there are two holes in the base for 2 12x3mm magnets. So i can place it inside my prusa enclosure. (in my case. left, next to the led.strip)
Publié : 27/09/2023 6:45 am
pingu
(@pingu)
am i stupid, or cant wlan password be only numbers?
when i enter my wlan password (only numbers) as variable, the password becomes blue, and i get error compiling.
edit: when i ad characters or letters before number, the number gehts white. but when i delete the wrong character it gets blue again.
Ce message a été modifié il y a 3 years par pingu
Publié : 10/10/2023 5:45 pm
Rainer
(@rainer-2)
My password has only numbers and it worked. Normally it outputs the error in the console.
Publié : 10/10/2023 6:03 pm
johnyHV
(@johnyhv)
No, you are changed variable name. You must update just variable value. For example, here is configuration, where WiFi SSID name is HomeNetwork, and password is 12345678
const char* ssid = "HomeNetwork";
const char* password = "12345678";
Publié : 11/10/2023 12:51 pm
stevo1957
(@stevo1957)
Guys, When purchasing the ESP32 camera and board, do I need to also buy an external antenna?
A lot of the suppliers on  AliExpress and Ebay have the antenna as an option.
Also, I note that some of the current boards now have an auto download function and no download button on the board. I assume these later versions would still be ok?
Publié : 17/10/2023 8:08 pm
Ckobar
(@ckobar)
My router and camera are in the same room. WLAN works without flaws.
Publié : 17/10/2023 8:26 pm
stevo1957
(@stevo1957)
Thanks.
My router is in the next room, about 6 metres away. Perhaps I'd better grab an external antenna just in case.
Publié : 17/10/2023 8:34 pm
Rainer
(@rainer-2)
But be careful what you buy. Often a kit with antenna is offered. But often a resistor must be diverted to be able to use the antenna. And this is really very small.
I have made the power supply directly to the module and not via the USB on the programming module. Then the wifi reception improved a lot. My router is also in another room 4m away.
Publié : 18/10/2023 3:09 am
chmax
(@chmax)
the smd resistor for switching the antenna from internal to external can be moved or, if it get lost like it happens to me all the times,  replaced by just a drop of solder... it works as well...
Publié : 18/10/2023 9:51 am
stevo1957
(@stevo1957)
Posted by: @rainer-2
Posted by: @chmax
Thanks for the info re the resistor guys. To include an external antenna with the kit is only about AUD $2.50 so I will add one just in case I have issues with the onn board antenna range.
Rainer, if I were to use a 5v power adapter could I connect this direct to the camera board, in an effort to boost the wifi? I'd rather not use the Mk4 to supply power at this stage. If I can use an external supply, which connection pins do I use?
Publié : 18/10/2023 11:20 am
Rainer
(@rainer-2)
Yes you can connect directly to the board. Where depends on your board. I don't know if they are all the same. But usually it is labeled grd/5v. I have used a USB charger and a cut off USB cable.
It was a big difference for me. Before I was thinking of buying another one or an antenna. Also the web interface was very slow. Now I am very satisfied. Works perfectly.
Publié : 18/10/2023 12:32 pm
Piotr W
(@piotr-w)
24V version, just change code for direct video stream
https://www.printables.com/pl/model/608451-mk4-esp32-cam-with-homeassistant-integration
Publié : 19/10/2023 7:31 pm
Ckhaney007
(@ckhaney007)
Membre
Error Compiling.... I checked i have all the correct versions of the libraries and board, but get the following:
Arduino: 1.8.19 (Mac OS X), Board: "AI Thinker ESP32-CAM, 240MHz (WiFi/BT), QIO, Huge APP (3MB No OTA/1MB SPIFFS), 80MHz, None, Disabled"[36835] Error loading Python lib '/var/folders/nv/qbt7dlms1mv7y323g0ht15gm0000gn/T/_MEIAhXSRH/libpython3.8.dylib': dlopen: dlopen(/var/folders/nv/qbt7dlms1mv7y323g0ht15gm0000gn/T/_MEIAhXSRH/libpython3.8.dylib, 10): Library not loaded: @loader_path/libintl.8.dylib  Referenced from: /var/folders/nv/qbt7dlms1mv7y323g0ht15gm0000gn/T/_MEIAhXSRH/libpython3.8.dylib  Reason: no suitable image found.  Did find: /var/folders/nv/qbt7dlms1mv7y323g0ht15gm0000gn/T/_MEIAhXSRH/libintl.8.dylib: cannot load 'libintl.8.dylib' (load command 0x80000034 is unknown) /private/var/folders/nv/qbt7dlms1mv7y323g0ht15gm0000gn/T/_MEIAhXSRH/libintl.8.dylib: cannot load 'libintl.8.dylib' (load command 0x80000034 is unknown)exit status 255/Users/Charlie/Desktop/Arduino.app/Contents/Java/arduino-builder returned 255Error compiling for board AI Thinker ESP32-CAM.This report would have more information with"Show verbose output during compilation"option enabled in File -> Preferences.
Publié : 27/12/2023 7:34 pm
Jerlo
(@jerlo)
Can someone make a tutorial video, I don't understand anything ?
Detecting libraries used..."C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\ESP32_PrusaConnectCam_web.ino.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\ESP32_PrusaConnectCam_web.ino.cpp"C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\camera.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\camera.cpp"C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\cfg.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\cfg.cpp"C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\server.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\server.cpp"C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\var.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\var.cppGenerating function prototypes..."C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\ESP32_PrusaConnectCam_web.ino.cpp" -o "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\preproc\\ctags_target_for_gcc_minus_e.cpp"xtensa-esp32-elf-g++: error: unrecognized command line option '-mfix-esp32-psram-cache-strategy=memw'
exit status 1Erreur de compilation pour la carte ESP32 Wrover ModuleBibliothèque non valide trouvée dans C:\Users\Jerlo\Documents\Arduino\libraries\lib : aucun fichier d'en-tête (.h) trouvé dans C:\Users\Jerlo\Documents\Arduino\libraries\libBibliothèque non valide trouvée dans C:\Users\Jerlo\Documents\Arduino\libraries\lib : aucun fichier d'en-tête (.h) trouvé dans C:\Users\Jerlo\Documents\Arduino\libraries\lib
Publié : 14/01/2024 1:14 pm
Fäbu
(@fabu)
Membre
RE: ESP32 Cam Support
I tried it with an M5STack Timercam and it worked perfectly. I just had to change the pin assignment. Many thanks for this ingenious solution.
Publié : 17/01/2024 7:51 pm
Fäbu
(@fabu)
Membre
Where are you stuck?
Posted by: @jerlo
Can someone make a tutorial video, I don't understand anything ?
Detecting libraries used..."C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\ESP32_PrusaConnectCam_web.ino.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\ESP32_PrusaConnectCam_web.ino.cpp"C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\camera.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\camera.cpp"C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\cfg.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\cfg.cpp"C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\server.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\server.cpp"C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\var.cpp" -o nulError while detecting libraries included by C:\Users\Jerlo\AppData\Local\Temp\arduino_build_967035\sketch\var.cppGenerating function prototypes..."C:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.6-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/console" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10810 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/build_opt.h" "@C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035/file_opts" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32" "-IC:\\Users\\Jerlo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\variants\\esp32" "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\sketch\\ESP32_PrusaConnectCam_web.ino.cpp" -o "C:\\Users\\Jerlo\\AppData\\Local\\Temp\\arduino_build_967035\\preproc\\ctags_target_for_gcc_minus_e.cpp"xtensa-esp32-elf-g++: error: unrecognized command line option '-mfix-esp32-psram-cache-strategy=memw'
exit status 1Erreur de compilation pour la carte ESP32 Wrover ModuleBibliothèque non valide trouvée dans C:\Users\Jerlo\Documents\Arduino\libraries\lib : aucun fichier d'en-tête (.h) trouvé dans C:\Users\Jerlo\Documents\Arduino\libraries\libBibliothèque non valide trouvée dans C:\Users\Jerlo\Documents\Arduino\libraries\lib : aucun fichier d'en-tête (.h) trouvé dans C:\Users\Jerlo\Documents\Arduino\libraries\lib
Publié : 17/01/2024 7:59 pm
jerzeek
(@jerzeek)
RE: ESP32 Cam Support
I made this:
It is for the Prusa Mini, But I am looking into ways to develop it for the MK4, but I don't have an MK4.
Let me know if you want one, or if I should document it somewhere
Publié : 30/01/2024 12:09 pm
1 personnes ont aimé
Mark18pll
(@mark18pll)
Which cable did you use to connect directly to the board, I am looking at this also, thanks
Publié : 09/02/2024 9:13 pm
Page 2 / 4
