Different hot blocks on the Mk4?
Samuel Miller
(@samuel-miller)
Hi all,
I'm just curious. I'm wondering if it would be possible to have a different hot block, for example, the Volcano or Copperhead on the Mk4, since the thread on the adapter seems like it would be possible. Obviously, if I were to do this, I would have to maybe change the fan shroud slightly, but do you think it would be beneficial or possible?
Napsal : 05/02/2024 12:17 am
Sergey
(@sergey)
Yes, it's possible and benefitial,
(I haven't tried this myself).
It's not clear to me why MK4 doesn't come with a longer hotend. Flow rate can be a limiting factors when running with input shaper even on a smaller printers, like Prusa Mini. The anemic flow rate of Plusa printers looks especially bad in XL.  I hope it gets fixed in the next iteration.
Napsal : 24/04/2024 6:30 am
Ron Williams
(@ron-williams)
RE: Different hot blocks on the Mk4?
Has anyone tried this ceramic heat block from amazon?  There's only 1 review:
https://www.amazon.com/dp/B0DBQC8LTD?ref=cm_sw_r_cso_cp_apin_dp_79F6GWHGKEQMMTWPAB1S&ref_=cm_sw_r_cso_cp_apin_dp_79F6GWHGKEQMMTWPAB1S&social_share=cm_sw_r_cso_cp_apin_dp_79F6GWHGKEQMMTWPAB1S&peakEvent=1&starsLeft=1&skipTwisterOG=1
Napsal : 05/12/2024 4:56 pm
