Anyone have any experience using Nozzle X on MK4
The adapter just went back in stock so I picked up the silicon sock, nozzle x, and the adapter. I've been running into a lot of issues on the MK4 with the first layer on PETG due to oozing before leveling, the nozzle cleaning is not enough and results in a layer that is too high unless I use the pliers just before probing.
Will the nozzle x work as a drop-in for everything, PLA, PETG, (I know it will be good for abrasives when I want to reprint my parts in CF).
Did you have to change your temperatures much and how was the print quality impacted/will it still work with the faster speeds of input shaping?
RE: Anyone have any experience using Nozzle X on MK4
Can't edit i swapped my order to the Obxidian V6
Did you change the complete MK4 noozle to a Obxidian V6 nozzle?
I want to order a new MK4 and want to print abrassive fillament. Any recommends for me?
The Prusa ObXidian nozzle came out.
I use nozzle X 0.4 and 0.6 on mk4 no issue here.
mini+ [bondtech dual drive, revo, reprinted with PA11-CF and ASA] lives in photo tent.
mk4 upgraded to S with mmu3 and gpio (with some parts reprinted) lives in prusa enclosure.
Voron 0 ldo kit with dragon burner and…
