Quick release for Silver PSU
GiantBrain
(@giantbrain)
i made a Mod and a Cover to use the Silver PSU with quick release. Check this out
For those who want to use a quick release with the silver power supply on the original Prusa Enclosure i share my info and sources.
Additionally I have designed a cover for the silver power supply. However, this can only be screwed after the PSU is attached to the housing, but that should not matter that much if your using the mod 🙂
Posted : 10/11/2022 6:47 pm
High Angle Video
(@high-angle-video)
RE: Quick release for Silver PSU
I am thinking of buying the enclosure.  I do have the silver PSU so just wanted to see how easy it would be to implement your quick release.
Posted : 28/11/2022 5:56 pm
GiantBrain
(@giantbrain)
I do not know your craftsmanship 😀 but if you have the necessary crimping pliers for the connectors it is not a big effort. If that is not the case but you can solder then that is also relatively easy to manage
Posted : 28/11/2022 6:32 pm
High Angle Video
(@high-angle-video)
I am fairly proficient since my background is in engineering.  I haven't worked much with my MK3S.  I also have a Palette Pro 3 sitting in a box that I haven't used.  I am hoping to get the enclosure mainly for sound reasons and dust.
Posted : 28/11/2022 7:14 pm
